Do I have the right lnb?
billsatelliteb
Jan 3, 2006
3
I am putting together a portable dish setup to use when I travel and am using parts from our home system, from a previous installation. before we went back to cable and now back to dish(long story:-()
Anyway, I have a Dish 500 dish with two LNB (P/N 214-5100-402) hooked to our dp 301 receiver.
I have hooked up to ONE of the two lnbs aimed, az, el and skew according to the on screen instructions. Used a "satellite finder." I get 119 very clearly but can not seem to lock onto 110. I am wondering if I should have some kind of switch between the lnb and the receiver or what. I followed the advice of one online source and ran the switch check, after I had acquired a satellite signal (119). I think I must be leaving out something to not be able to lock on to 110.
Any suggestions, thanks, bill b.
KE4EST
SatelliteGuys Is My Second Home
Staff member
HERE TO HELP YOU!
27,086
7,412
EM75xb
What you have are legacy LNBS, so it would work, but you need a SW-21 Switch, to get both Sats.
billsatelliteb
Jan 3, 2006
3
Great. Thanks for the information. I presume that I would run one cable from each LNB to the switch? that would give me both sats.
thanks, again, bill b.
BobaBird
1,693
EKB Annex
The LNBs are probably legacy. They should be marked "Digital LNBF" and not have a large dp logo. Then hook up the SW21 as you described and run a Check Switch.
billsatelliteb
Jan 3, 2006
3
Check switch ordered
Thanks, the lnbf s do say "digital" and no dp logo. So I have ordered an SW21 and will hook 'em up and run check switch and should be good to go.
thanks, bill b.
Johnstown / Altoona DMA in HD on 4/22 ??
Where is KBS World TV?
