4/23/2009 2:26am - Uplink Activity Report - 52 changes
D
DigiSAT Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 4/23/2009 2:26am - 52 changes
Uplink Comparison Range: 04/23/2009 01:58A - 04/23/2009 02:26A
Channel Additions:
177 - TOONW [MPEG2 SD] added to EchoStar11 110W TP 19 ConUS beam (A)
177 - TOONW [MPEG4 SD] added to Echostar6 72.7W TP 01 ConUS beam (A)
Channel Removals:
177 - NICKG (A) removed from EchoStar11 110W TP 15 ConUS beam
177 - NICKG (A) removed from EchoStar8 77W TP 29 ConUS beam
4826 - TMP56 (NA) removed from Ciel-2 129W TP 30 ConUS beam
4826 - TMP56 (NA) removed from EchoStar3 61.5W TP 30 ConUS beam
Channel Moves:
181 - TOONW [MPEG2 SD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 15 ConUS beam (A)
181 - TOONW [MPEG4 SD] moved from Echostar6 72.7W TP 01 ConUS beam to EchoStar8 77W TP 29 ConUS beam (A)
385 - MGM [MPEG4 HD] moved from Ciel-2 129W TP 17 ConUS beam to Ciel-2 129W TP 19 ConUS beam (A)
394 - WFN [MPEG4 HD] moved from Ciel-2 129W TP 17 ConUS beam to Ciel-2 129W TP 22 ConUS beam (A)
4108 - LIFE [MPEG4 HD] moved from Ciel-2 129W TP 23 ConUS beam to Ciel-2 129W TP 17 ConUS beam (A) (H)
4118 - A&E [MPEG4 HD] moved from Ciel-2 129W TP 27 ConUS beam to Ciel-2 129W TP 28 ConUS beam (A) (H)
4139 - TBS [MPEG4 HD] moved from Ciel-2 129W TP 24 ConUS beam to Ciel-2 129W TP 26 ConUS beam (A) (H)
4182 - DISC [MPEG4 HD] moved from Ciel-2 129W TP 19 ConUS beam to Ciel-2 129W TP 17 ConUS beam (A) (H)
4183 - TLC [MPEG4 HD] moved from Ciel-2 129W TP 19 ConUS beam to Ciel-2 129W TP 17 ConUS beam (A) (H)
4206 - FOXB [MPEG4 HD] moved from Ciel-2 129W TP 28 ConUS beam to Ciel-2 129W TP 29 ConUS beam (A) (H)
4285 - MGM [MPEG4 HD] moved from Ciel-2 129W TP 17 ConUS beam to Ciel-2 129W TP 19 ConUS beam (A) (H)
4294 - WFN [MPEG4 HD] moved from Ciel-2 129W TP 17 ConUS beam to Ciel-2 129W TP 22 ConUS beam (A) (H)
4807 - TMP37 [MPEG4 HD] moved from Ciel-2 129W TP 26 ConUS beam to Ciel-2 129W TP 24 ConUS beam (NA)
4815 - TMP45 [MPEG4 HD] moved from Ciel-2 129W TP 28 ConUS beam to Ciel-2 129W TP 27 ConUS beam (NA)
4816 - TMP46 [MPEG4 HD] moved from Ciel-2 129W TP 28 ConUS beam to Ciel-2 129W TP 27 ConUS beam (NA)
4827 - TMP57 [MPEG4 HD] moved from Ciel-2 129W TP 17 ConUS beam to Ciel-2 129W TP 23 ConUS beam (NA)
4827 - TMP57 [MPEG4 HD] moved from EchoStar3 61.5W TP 32 ConUS beam to EchoStar3 61.5W TP 30 ConUS beam (NA)
5312 - A&E [MPEG4 HD] moved from Ciel-2 129W TP 27 ConUS beam to Ciel-2 129W TP 28 ConUS beam (A) (H)
5318 - CMT [MPEG4 HD] moved from Ciel-2 129W TP 23 ConUS beam to Ciel-2 129W TP 17 ConUS beam (A) (H)
5319 - VH1 [MPEG4 HD] moved from Ciel-2 129W TP 27 ConUS beam to Ciel-2 129W TP 28 ConUS beam (A) (H)
5330 - DISC [MPEG4 HD] moved from Ciel-2 129W TP 19 ConUS beam to Ciel-2 129W TP 17 ConUS beam (A) (H)
5331 - TLC [MPEG4 HD] moved from Ciel-2 129W TP 19 ConUS beam to Ciel-2 129W TP 17 ConUS beam (A) (H)
5343 - LIFE [MPEG4 HD] moved from Ciel-2 129W TP 23 ConUS beam to Ciel-2 129W TP 17 ConUS beam (A) (H)
5352 - TBS [MPEG4 HD] moved from Ciel-2 129W TP 24 ConUS beam to Ciel-2 129W TP 26 ConUS beam (A) (H)
5369 - MGM [MPEG4 HD] moved from Ciel-2 129W TP 17 ConUS beam to Ciel-2 129W TP 19 ConUS beam (A) (H)
5372 - WFN [MPEG4 HD] moved from Ciel-2 129W TP 17 ConUS beam to Ciel-2 129W TP 22 ConUS beam (A) (H)
5500 - HDTHR [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46 to EchoStar11 110W TP 13 ConUS beam (A) (H)
5501 - TNT [MPEG4 HD] moved from EchoStar10 110W TP 27 Spotbeam 46 to EchoStar11 110W TP 07 ConUS beam (A) (H)
5505 - ESPN [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46 to EchoStar11 110W TP 07 ConUS beam (A) (H)
5510 - HDNET [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46 to EchoStar11 110W TP 07 ConUS beam (A) (H)
5511 - HDNMV [MPEG4 HD] moved from EchoStar10 110W TP 12 Spotbeam 46 to EchoStar11 110W TP 07 ConUS beam (A) (H)
5515 - HBO [MPEG4 HD] moved from EchoStar10 110W TP 27 Spotbeam 46 to EchoStar11 110W TP 13 ConUS beam (A) (H)
5516 - SHO-E [MPEG4 HD] moved from EchoStar10 110W TP 27 Spotbeam 46 to EchoStar11 110W TP 13 ConUS beam (A) (H)
9419 - A&E [MPEG4 HD] moved from Ciel-2 129W TP 27 ConUS beam to Ciel-2 129W TP 28 ConUS beam (A)
9440 - MAX-W [MPEG4 HD] moved from Ciel-2 129W TP 29 ConUS beam to Ciel-2 129W TP 28 ConUS beam (A)
9470 - LIFE [MPEG4 HD] moved from Ciel-2 129W TP 23 ConUS beam to Ciel-2 129W TP 17 ConUS beam (A) (H)
9476 - FOXB [MPEG4 HD] moved from Ciel-2 129W TP 28 ConUS beam to Ciel-2 129W TP 29 ConUS beam (A) (H)
9478 - HBO-W [MPEG4 HD] moved from Ciel-2 129W TP 22 ConUS beam to Ciel-2 129W TP 17 ConUS beam (A) (H)
9479 - ACMAX [MPEG4 HD] moved from Ciel-2 129W TP 17 ConUS beam to Ciel-2 129W TP 19 ConUS beam (A) (H)
9487 - DISC [MPEG4 HD] moved from Ciel-2 129W TP 19 ConUS beam to Ciel-2 129W TP 17 ConUS beam (A)
9488 - TLC [MPEG4 HD] moved from Ciel-2 129W TP 19 ConUS beam to Ciel-2 129W TP 17 ConUS beam (A)
9493 - CMT [MPEG4 HD] moved from Ciel-2 129W TP 23 ConUS beam to Ciel-2 129W TP 17 ConUS beam (A)
9499 - TBS [MPEG4 HD] moved from Ciel-2 129W TP 24 ConUS beam to Ciel-2 129W TP 26 ConUS beam (A)
9507 - VH1 [MPEG4 HD] moved from Ciel-2 129W TP 27 ConUS beam to Ciel-2 129W TP 28 ConUS beam (A)
36852 - DNL11 [143] moved from Ciel-2 129W TP 25 ConUS beam to Ciel-2 129W TP 30 ConUS beam (A)
36852 - DNL11 [143] moved from EchoStar3 61.5W TP 29 ConUS beam to EchoStar3 61.5W TP 32 ConUS beam (A)
Channels in the system: 6418
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Boo...TMP56 removed. :( Now, DISH is removing HD channels before they even become available. The ultimate cost cutting move! :)
Looks like they are moving more and more things over to Ciel-2. But I wonder what all the TMPS are.
Where do you see them moving more things to Ciel-2?
Here is a stunning relevation not previously revealed at any point in the 21st Century:
Reading requires your eyes looking at every word in the sentence, in order, from left to right.
:eek: :eek: :eek: :eek: :eek: :eek:
This is a Satellite Guys Exclusive !
You will not find this anywhere else on the Internet...
ROFLMAO!!! :D:haha
dish 500AK to look at 119/129 for alaska and dish 500H for hawaii will look at 119/110.
Nearly all HD except platinum to be available to alaska and hawaii.
OK, where do you get your info from? I looked up dish 500AK on Google and I'm not convinced a 22" dish would work here. It would be nice if it would, lot less hardware.
not in position to know specifics of it. posting why i know is risky to me to do so.
however, if all hd is being put on spotbeams for ak and spotbeams are stronger, than perhaps that will overcome dish size.
I guess just wait for may 8th, or a few weeks after that...:rolleyes:
D
4/24/2009 12:14pm - Uplink Activity Report - 3 changes
D
4/27/2009 11:18am - Uplink Activity Report - 2 changes
