One of my locals picture size has shrunk, Why?
I think hendrix04 may be on to the issue"Now, as far as what you're seeing... somewhere a downconverter is set to letterbox. The problem with this is when you letterbox a 4x3 program (many commercials, all soap operas, some other shows), you end up putting black bars on all four sides. If you watch a 4x3 program on a 16x9 set, you should have black bars on the left and right. But keep in mind, the "letterbox" setting on the downconverter shows EVERYTHING from the original 16x9 image... in this case, including the black bars on the left & right. So now you see black bars on all four sides... also known as "postage stamp". The problem is with either dish or the local. Just to clarify , I get a postage stamp picture on both my 4x3's and my 16x9's when I watch a show such as seinfeld on any receiver.
I was also able to scan ch 55 in from cox cable and compare to the dish feed on the same TV, and the picture is normal not postage size like dish. I'm leaning towards the local channel being the problem, after all it's the CW network maybe they don't have enough money for the proper equipment. All my other locals are normal.
Just because your other locals are normal doesn't mean the problem is at the station. Dish has a receiver for every station in the market. Assuming you're watching an SD version of the station, Dish downconverts the signal. THAT'S where it sounds like the problem is. Comparing the same channel on cable vs. satellite shows the problem on Dish only, right? THAT points to Dish right there.
Here's what (I think) is happening... let's use Seinfeld as an example. The show is 4:3. If you use OTA to watch the show (using an ATSC tuner), the show would fill a 4:3 set and you'd have black bars left & right on a 16:9 set (barring 'zooming' or otherwise messing with the picture).
The TV station is ALWAYS sending a 16:9 image (even if the left & right parts of the screen are black). The cable company is "center cutting" the image so you don't see the black on the sides and everything would show up like I described in the previous paragraph. Dish however is "letterboxing" the image. The letterbox puts black bars top & bottom (so you can see the full 16:9 image in a 4:3 screen). But since, during Seinfeld and other 4:3 programming, there's already black bars L&R, you now have black bars on all four sides. It would actually look SMALLER on a 16:9 set, because the image from dish is just filling the 4:3 "window" in the center.
Sounds like you may be right, but why would it be only one local that dish is not broadcasting like the rest? also is it a problem they can or will fix? It's not really that big a deal for me since seinfeld and the king of queens are the only shows I watch now. I watch them on 55 because they don't edit out as much of the show as TBS does for more commercial space, also none of those annoying bottom banner ads. Plus win football season gets here they have some games not available on other channels I get.
The problem is spatial scaling that occurred at the point of Dish receiving the local broadcast. They aren't receiving enough signal from the broadcaster and their decoder scaled the picture. That is how it was received and decoded, and that is what they send.
1 term
It has to do with low signal strength or poor signal quality.
The shrunken picture is a type of scalability that is built into the MPEG forward error correction. Your television receivers AND your Dish receivers (Directv, digital cable) everything using MPEG 2/4 has scalability, built right in.
When you have less than the minimum of 70 on a standard digital signal quality meter (everyone's meter except the new improved dish signal meter where there is no longer any standard...), there is built-in or rather "written" in, coding that allows for the decoding of a weaker, or compromised signal. It is called Scalable Video Coding extension, and has been a part of HDTV since at least 2005.
One of the types of scalability that is available to use, is spatial scalability. This scalability says, "Since the signal is poor and there is not enough data to produce the full size picture at the proper resolution, then I'll display the proper quality, or resolution, at a reduced size."
These are three types of scalability. They are temporal, spatial, and fidelity scaling options. Broadcasters and TV manufacturers use all three of these handy, low-signal digital tricks.
Spatial scalability is what you are witnessing on your TV. Here the quality remains but the size of the picture decreases. Dish does NOT use this type of scaling because it too easily leads to the truth of the picture/signal relationship.
Fidelity scalability is scaling that reduces the quality of the picture (grainy, blurry) but maintains size. Since most people don't see this difference, and the perpetuation of the "all-or-nothing LIE" says that signal is NEVER the problem, this type of scaling is acceptable to Dish.
Temporal scalability refers to time scalability and accounts for a good portion of the audio sync problems that are being reported. Since these also have a reputation of being blamed on software issues and such, so this scaling is also acceptable.
The rest of the story is on WOWVision and the HDTV Picture Quality blog.
The link to the technical info regarding SVC scaling follows:
http://ip.hhi.de/imagecom_G1/assets/pdfs/Overview_SVC_IEEE07.pdf
BS. Definitions of the terms you are using.
* Temporal (frame rate) scalability: the motion compensation dependencies are structured so that complete pictures (i.e. their associated packets) can be dropped from the bitstream. (Temporal scalability is already enabled by H.264/MPEG-4 AVC. SVC has only provided supplemental enhancement information to improve its usage.)
* Spatial (picture size) scalability: video is coded at multiple spatial resolutions. The data and decoded samples of lower resolutions can be used to predict data or samples of higher resolutions in order to reduce the bit rate to code the higher resolutions.
* SNR/Quality/Fidelity scalability: video is coded at a single spatial resolution but at different qualities. The data and decoded samples of lower qualities can be used to predict data or samples of higher qualities in order to reduce the bit rate to code the higher qualities.
* Combined scalability: a combination of the 3 scalability modalities described above.
These are not related to retransmission by satellite. They are related to the original source and what is done from:
* Streaming
* Conferencing
* Surveillance
* Broadcast
* Storage
E* takes these sources as given to them and just rebroadcast them after the satellite encoding process. If signal level is too low they loose the source and call the provider. The do not change these qualities. Signal level has little to do with any of these. It is either working, pixelating, or gone nothing else. How do I know these things I work for one of E*'s providers and if they loose the signal they call us almost instantly.
By inspiration...
* Temporal (frame rate) scalability: the motion compensation dependencies are structured so that complete pictures (i.e. their associated packets) can be dropped from the bitstream. (It is not so that packets CAN be dropped from the bitstream, but instead, it is for when there have been packets dropped before decoding. It enables a lower quality reconstruction which is especially noticable during fast motion sequences.). (Temporal scalability is already enabled by H.264/MPEG-4 AVC. SVC has only provided supplemental enhancement information to improve its usage.) (Temporal scalability is the primary cause of motion blur in low signal systems. Motion blur arises from poor signal quality, but calibration should be considered in the equation to a lesser extent.)
* Spatial (picture size) scalability: video is coded at multiple spatial resolutions. (Correct.) The data and decoded samples of lower resolutions can be used to predict data or samples of higher resolutions (Correct, but when slow data, poor signal quality, or burst noise occurs, the amount of data available can be less than is required for the reconstruction of the higher resolution picture at the desired size. With spatial scaling, the quality remains high, but it has only enough information to produce the higher quality in a smaller size, or using a smaller number of pixels.) in order to reduce the bit rate to code the higher resolutions.
* SNR/Quality/Fidelity scalability: video is coded at a single spatial resolution but at different qualities. (Correct. The data and decoded samples of lower qualities are used when there is too much corrupted data, as in a low signal quality situation. The result is a picture of the correct size, but it has less detail. This is what is refered to as the "blurry" or "blotchy" picture that is regularly reported by users.) The data and decoded samples of lower qualities can be used to predict data or samples of higher qualities in order to reduce the bit rate to code the higher qualities. (Lesser quality data is used in the presence of a lack of high quality data.)
These are not related to retransmission by satellite. (They are related to They are related to the original source and what is done from:
* Streaming
* Conferencing
* Surveillance
* Broadcast
* Storage
E* takes these sources as given to them and just rebroadcast them after the satellite encoding process. (Just what I said. Dish received a compromised signal from the broadcaster and the SVC scaling gave them the required resolution in smaller size. They sent what they got. That is why none of the formating options would do anything to change the picture.) If signal level is too low they loose the source and call the provider. The do not change these qualities. ("They" do not have the ability to change these qualities. The decoders within digital receivers do this without any input other than the quality of the signal that they have to work with.) Signal level has little to do with any of these. (Signal level/quality/fidelity has EVERYTHING to do with these. Signal-to-noise ratio is still the measurement of signal quality/fidelity. Signal-to-noise ratio is analog at the antenna, and it is the quantity that gives BER. Bit error rate determines quality. Forward error correction is based on a minimum signal to achieve the Quasi Error Free point of operation. Quasi means "Fake, or copy". The quasi error free point of operation is 70 on all systems I've used including Dish Network...until recently...) It is either working, pixelating, or gone nothing else. (Incorrect. It takes only a little research to determine that this is not the case. A quote from an article regarding MPEG's Scalable Video Coding (SVC - previously known as Signal-to-noise Scalability or SNR scalability)
"In general, a video bit stream is called scalable when parts of
the stream can be removed in a way that the resulting substream
forms another valid bit stream for some target decoder, and the
substream represents the source content with a reconstruction
quality
that is less than that of the complete original bit stream
but is high when considering the lower quantity of remaining
data."
and,
"SVC provides functionalities such as graceful
degradation in lossy transmission environments
as well as bit
rate, format, and power adaptation."
How do I know these things? I have no degrees. I have no formal training. I have searched to know the truth of picture quality and the signal relationship since 2005. I am one of whom it is written:
1 Corinthians 1:27-29 KJVR But God hath chosen the foolish things of the world to confound the wise; and God hath chosen the weak things of the world to confound the things which are mighty; (28) And base things of the world, and things which are despised, hath God chosen, yea, and things which are not, to bring to nought things that are: (29) That no flesh should glory in his presence.
Jeremiah 33:3 KJVR Call unto me, and I will answer thee, and shew thee great and mighty things, which thou knowest not.
All right Jeff. I've been defending your position in at least two other threads. But I think you diagnosis is wrong on this particular problem, and the broadcast engineer (Sam Gordon?) is right. Some boob is incorrectly downconverting a 4:3 picture, either at the station or at Dish. When the culpable party notices his goof, he'll simply flip a switch somewhere and fix it. That is my prediction.
As for spatial scaling, I agree with you that it exists and it's visible, but it's not that visible! ("That" being to frame the entire picture in black.) What I believe this refers to is one type of error compensation where the video is reproduced at a lower resolution than it started out, because not enough data made it through intact to reconstruct the original picture in all it's pristine digital high-res perfection. It should still display at the same total size on your screen (not picture-framed!), resulting in a transient blurriness as the scalers inside the receiver do their interpolative magic.
jeff-
Want to actually TEST your theory instead of just trying to read white papers? Setup an OTA antenna, tuner, and TV. Tune in a local signal. Now, move the antenna AWAY from the transmit tower. Watch your signal level drop. Does the picture "SHRINK"?
I'm willing to bet as the signal level drops, first you'll see no change, then you'll see increased macroblocking/pixelization/freezes, then the "no signal".
Go ahead, try it. We'll wait.
Ignore hideafjeff, he's constantly spitting out his propaganda that you don't have a good HD picture unless you have maxed out your dish. But this by far my favorite! It just so happened to drop signal on the side bars of the screen causing them to go black. LOL!!! AMAZING!! Maybe it's because the guy has a square LNB and not a rectangular 16:9 LNB right? ;)
:D :D :D
You guys are still entertaining deafjeff eh? ;) He's fun....
It would seem so. :o He appears to be on a crusade. And while I think some ire is warranted, error compensation in poor signal conditions is a good thing not a bad thing.
Parable of the day: when all you have is a hammer, everything looks like a nail.
jeff-
I already have witnessed it, and can recreate it.
A couple months ago, after a visit to my parents home, my Dad called me and asked why his picture was changing sizes since I left. I asked if it was when a commercial came on or went off. He said it was "anytime, during a commercial or during a program". I told him I'd have to come see. So I went and, lo and behold, the TV was doing it when I got there.
I was stumped on this one. When it shrank to postage size, using the format button would not change it. I did realize that I had left the auto format on, and so I turned auto format back off, and switched to a single format choice. The size of the picture then remained as it was set. I told my Dad that this was a new one on me, but I'd roll that one around for awhile and something would come to light.
What you don't know is that I live 30 miles from the transmitters and daily watch marginal OTA signal on a converter box. My parents also have low signal from their existing antenna, which I have left that way for research. (I get to see alot more aberrations that way, and they usually watch recorded stuff from the DVR.)
I had been searching since 2005 for the science behind digital picture quality variation in low signal environments when I found that the answer for both picture quality and size change was contained in MPEG SVC extension. Scalable video coding. (Previously known as Signal-to-noise Ratio (SNR) Scaling.
The name of the article is:
"Overview of the Scalable Video Coding Extension of the H.264/AVC Standard"
(Let me just add here that the previous name of SVC scalability was SNR scalability. That's Signal-to-Noise Ratio Scalability.)
The abstract states it very simply:
Abstract—With the introduction of the H.264/AVC video coding standard, significant improvements have recently been demonstrated in video compression capability. The Joint Video Team of the ITU-T VCEG and the ISO/IEC MPEG has now also standardized a Scalable Video Coding (SVC) extension of the H.264/AVC standard. SVC enables the transmission and decoding of partial bit streams to provide video services with lower temporal or spatial resolutions or reduced fidelity while retaining a reconstruction quality that is high relative to the rate of the partial bit streams. Hence, SVC provides functionalities such as graceful degradation in lossy transmission environments as well as bit rate, format, and power adaptation.
And,
Moreover, the basic tools for providing temporal, spatial, and quality scalability are described in detail and experimentally analyzed regarding their efficiency and complexity.
Index Terms—H.264/AVC, MPEG-4, Scalable Video Coding (SVC), standards, video.
All right Jeff. I've been defending your position in at least two other threads. (And I THANK YOU! I am sorry for this long overdue appreciation...I should read all the posts once in awhile.) But I think you diagnosis is wrong on this particular problem, and the broadcast engineer (Sam Gordon?) is right. (And I appreciate your opinion!) Some boob is incorrectly downconverting a 4:3 picture, either at the station or at Dish. When the culpable party notices his goof, he'll simply flip a switch somewhere and fix it. That is my prediction.
As for spatial scaling, I agree with you that it exists and it's visible, but it's not that visible! ("That" being to frame the entire picture in black.) It is exactly THAT VISIBLE. Spatial scaling that I have witness - and according to all I've read - does exactly "that". I do know the difference between a combination of letterbox and sidebars (which will respond to format buttons) and a solid black frame around the picture that doesn't respond to a format button. What I believe this refers to is one type of error compensation where the video is reproduced at a lower resolution than it started out, because not enough data made it through intact to reconstruct the original picture in all it's pristine digital high-res perfection. It should still display at the same total size on your screen (not picture-framed!), resulting in a transient blurriness as the scalers inside the receiver do their interpolative magic.
When you describe full screen with blurriness, that is an example of fidelity/quality scaling. When I describe the "postage stamp' screen (Full quality/fidelity, smaller size) that is an example of spatial scaling (less space but proper resolution). There is also temporal scaling but I'm not going to get into it here.
When all is said and done, either of us could be right. Whether it was a flip of a switch or the effects of scaling at the provider, I don't expect anyone to get an answer to this one.
Thank you again for speaking up. A person either has to have seen it (PQ variances) on their television or they have to be searching for the quality they've seen elsewhere to know that digital picture quality varies. Experience in correcting these issues, and digital science, both attest to the signal/PQ relationship.
I still think the guy's LNB that he got installed was a 4:3 LNB and not a 16:9 LNB.
Just like back in the day you had to make sure you bought a color TV antenna and not a black&white one...also like you have to buy a HDTV antenna to pick up digital signals. ;) ;)
Dish remote code for Sharp LC-32SB24U?
External hard drive fee?
