What dish is used to receive standard programming?
iafirebuff
4,394
8
Waterloo, Iowa
Well my wife decided to dump cable (yeah) and go back to Directv. Now when we left back in 07 we had 2 - 18" dishes that were feeding 3 SD DVRs. We have signed up for a SD package with 2 - DVRs, and I am wondering what dish antenna they will be sending for me to setup? THANKS for the info!
Dish 500, Unless you are an Eastern Arc City, Then a 1000.4
Dish 500 Dual LNBs 20x22 ,Serves 2 Dual room Receivers Single wire
Dish 1000.4 Triple LNBs 19x24, Serves 3 Dual room receivers single wire
This is in the DirecTV forum so I assume they will install a Slimline. But if its SD only, an 18" dish pointed at 101 will work fine.
Edit: P Smith types faster ;)
Tell me that ! Those listed by you Dish dishes use DiSEqC or Dish proprietary command to swith LNBF/sats. While DTV used simple 22 KHz switching scheme.
Hello ?
THANKS for the input! I am doing a self install. I have no problem with the 2 18" dishes. I have never installed a slimline before. I have done Dish 1000's though. I hope they are not too bad :)
but according to the Directv website, his area still needs 2 dishes
Waterloo is in the Cedar Rapids, DMA
Cedar Rapids, IA**
**Receipt of local channels in these markets requires a DIRECTV® Multi-Satellite Receiver with APG and the use of a second 18-inch DIRECTV Dish.
Larry you will still need the 2 dishes
one at 101 for main programming
one at 72.5 for locals
Cedar Rapids, IA**
This is True. if your locals are on I believe the 72.5 or 95 Orbital location?
they would be on the 72.5 slot which Lyngsat shows
since he isnt doing HD the 2 dish setup is what he needs
Left Dish After 5 Years
