hooking up phone line to a 612?
KAB
21,737
5,226
Fishers, IN
With line connected, go Menu, 6, 3...Connection. Select and see what phone connection report says.
generj
59
3
Per the dish vip612 product launch bulletin, if you plug a phone line into the ethernet plug, all of your phones will go dead.
Hope this helps......
KAB
21,737
5,226
Fishers, IN
AH-HA!!! Give that man a cigar!!
kstile
258
If it matters, you don't have to have the 612 plugged into a phone line if you don't want to. That requirement is only for receivers which can accommodate 2 TVs.
catman60
SatelliteGuys Guru
Aug 30, 2009
132
michigan
yes it was in the wrong hole! i have to start looking for holes instead of feeling for them.ha! ha!
aklarvanto
SatelliteGuys Guru
Jun 19, 2009
143
Wasilla, Alaska
I wonder if anyone has similar problem. I have both, broadband and phoneline connected and my Vip612 does not work over phoneline. If I try to connect to customer service, view bill or whatever you can normally do with dialup, I get error 9. I tried to fix this one time with customer service on the phone and he was glueless.
He was blaming faulty wiring in house but that does not make sense because my other receivers work just fine and I had 508 in the same spot before. When I run connection check it say both are OK. I have not try this yet but if I disconnect phoneline, will customer service work over broadband only?
