D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 9/30/2009 1:40pm - 148 changes
Uplink Comparison Range: 09/30/2009 01:24P - 09/30/2009 01:40P
Channel Additions:
141 - ESPNU [MPEG2 SD] added to EchoStar7 119W TP 04 ConUS beam (A) (H)
141 - ESPNU [MPEG4 SD] added to Echostar6 72.7W TP 23 ConUS beam (A) (H)
531 - PPV [MPEG2 SD] added to EchoStar11 110W TP 10 ConUS beam (NA)
533 - PPV [MPEG2 SD] added to EchoStar7 119W TP 16 ConUS beam (NA)
534 - $1.99 [MPEG2 SD] added to EchoStar11 110W TP 06 ConUS beam (A)
534 - $1.99 [MPEG4 SD] added to EchoStar8 77W TP 12 ConUS beam (A)
549 - HDPPV [MPEG4 HD] added to EchoStar11 110W TP 13 ConUS beam (A)
549 - HDPPV [MPEG4 HD] added to Echostar6 72.7W TP 17 ConUS beam (A)
651 - CLRS [MPEG2 SD] added to EchoStar3 61.5W TP 10 ConUS beam (NA)
856 - UTLSM [MPEG2 SD] added to EchoStar11 110W TP 16 ConUS beam (NA)
6085 - HISTI [MPEG2 SD] added to EchoStar11 110W TP 01 ConUS beam (NA)
6085 - HISTI [MPEG4 SD] added to Echostar6 72.7W TP 11 ConUS beam (NA)
6086 - BIO [MPEG2 SD] added to EchoStar11 110W TP 05 ConUS beam (NA)
6086 - BIO [MPEG4 SD] added to Echostar6 72.7W TP 03 ConUS beam (NA)
6087 - BIO [MPEG4 HD] added to Ciel-2 129W TP 29 ConUS beam (NA)
6087 - BIO [MPEG4 HD] added to EchoStar3 61.5W TP 16 ConUS beam (NA)
6088 - HMC [MPEG2 SD] added to EchoStar11 110W TP 01 ConUS beam (NA)
6088 - HMC [MPEG4 SD] added to Echostar6 72.7W TP 01 ConUS beam (NA)
6089 - HMC [MPEG4 HD] added to Ciel-2 129W TP 29 ConUS beam (NA)
6089 - HMC [MPEG4 HD] added to EchoStar3 61.5W TP 16 ConUS beam (NA)
6090 - ID [MPEG2 SD] added to EchoStar11 110W TP 09 ConUS beam (NA)
6090 - ID [MPEG4 SD] added to Echostar6 72.7W TP 03 ConUS beam (NA)
6091 - VS. [MPEG2 SD] added to EchoStar11 110W TP 21 ConUS beam (NA)
6091 - VS. [MPEG4 SD] added to Echostar6 72.7W TP 05 ConUS beam (NA)
6092 - VS. [MPEG4 HD] added to Ciel-2 129W TP 29 ConUS beam (NA)
6092 - VS. [MPEG4 HD] added to EchoStar3 61.5W TP 16 ConUS beam (NA)
6093 - GAC [MPEG2 SD] added to EchoStar11 110W TP 11 ConUS beam (NA)
6093 - GAC [MPEG4 SD] added to Echostar6 72.7W TP 05 ConUS beam (NA)
6094 - FUSE [MPEG2 SD] added to EchoStar7 119W TP 02 ConUS beam (NA)
6094 - FUSE [MPEG4 SD] added to Echostar6 72.7W TP 05 ConUS beam (NA)
6095 - WE [MPEG2 SD] added to EchoStar7 119W TP 12 ConUS beam (NA)
6095 - WE [MPEG4 SD] added to Echostar6 72.7W TP 15 ConUS beam (NA)
6096 - IFC [MPEG2 SD] added to EchoStar7 119W TP 06 ConUS beam (NA)
6096 - IFC [MPEG4 SD] added to Echostar6 72.7W TP 15 ConUS beam (NA)
6097 - CI [MPEG4 HD] added to EchoStar11 110W TP 19 ConUS beam (NA)
6097 - CI [MPEG4 HD] added to EchoStar8 77W TP 13 ConUS beam (NA)
6098 - AMC [MPEG2 SD] added to EchoStar7 119W TP 08 ConUS beam (NA)
6098 - AMC [MPEG4 SD] added to Echostar6 72.7W TP 09 ConUS beam (NA)
6099 - LMN [MPEG2 SD] added to EchoStar11 110W TP 02 ConUS beam (NA)
6099 - LMN [MPEG4 SD] added to Echostar6 72.7W TP 09 ConUS beam (NA)
6100 - LMN [MPEG4 HD] added to Ciel-2 129W TP 23 ConUS beam (NA)
6100 - LMN [MPEG4 HD] added to EchoStar3 61.5W TP 20 ConUS beam (NA)
9374(2) - KUNW [MPEG2 SD] added to EchoStar10 110W TP 12 Spotbeam 45 (NA)
9483(82) - NFLRZ [MPEG4 HD] added to Ciel-2 129W TP 27 ConUS beam (A)
9483(82) - NFLRZ [MPEG4 HD] added to EchoStar3 61.5W TP 20 ConUS beam (A)
Channel Removals:
14089 - KSCI6 (NA) removed from EchoStar7 119W TP 01 Spotbeam 5
14843 - KPXJ4 (NA) removed from EchoStar10 110W TP 18 Spotbeam 15
14662 - KMIZ4 (NA) removed from EchoStar10 110W TP 26 Spotbeam 19
14237 - WIVB3 (NA) removed from EchoStar10 110W TP 27 Spotbeam 09
14240 - WNLO2 (NA) removed from EchoStar10 110W TP 27 Spotbeam 09
14578 - WKBW2 (NA) removed from EchoStar10 110W TP 27 Spotbeam 09
15200 - WKBW3 (NA) removed from EchoStar10 110W TP 27 Spotbeam 09
15123 - WLIW4 (NA) removed from EchoStar10 110W TP 20 Spotbeam 04
14831 - WPGH2 (NA) removed from EchoStar10 110W TP 29 Spotbeam 09
5104 - KEVN (A) (H) removed from EchoStar7 119W TP 10 ConUS beam(Rapid City, SD-FOX)
5135 - KFNB (A) (H) removed from EchoStar7 119W TP 10 ConUS beam(Casper, WY-FOX)
141 - ESPNA (A) removed from EchoStar11 110W TP 24 ConUS beam
141 - ESPNA (A) removed from Echostar6 72.7W TP 29 ConUS beam
533 - $1.99 (A) removed from EchoStar11 110W TP 06 ConUS beam
533 - $1.99 (A) removed from EchoStar8 77W TP 12 ConUS beam
534 - HDPPV (A) removed from Ciel-2 129W TP 31 ConUS beam
534 - HDPPV (A) removed from Echostar6 72.7W TP 17 ConUS beam
Channel Moves:
8416 - KPXD [MPEG4 SD] moved from Echostar12 61.5W TP 15 Spotbeam 17 to Echostar12 61.5W TP 01 Spotbeam 16 (A) (H)(Arlington, TX-N/A)
8411 - KXTX [MPEG4 SD] moved from Echostar12 61.5W TP 15 Spotbeam 17 to Echostar12 61.5W TP 01 Spotbeam 16 (A) (H)(Dallas, TX-N/A)
8410 - KSTR [MPEG4 SD] moved from Echostar12 61.5W TP 15 Spotbeam 17 to Echostar12 61.5W TP 01 Spotbeam 16 (A) (H)(Irving, TX-TLF)
548 - HDPPV [MPEG4 HD] moved from EchoStar11 110W TP 13 ConUS beam to Ciel-2 129W TP 31 ConUS beam (A)
Channel Package Flag Changes:
7058(31) - KDCU [MPEG2 SD] - EchoStar10 110W TP 29 Spotbeam 29 changed to Available (H)(Derby, KS-UNI)
230 - ICTV [MPEG4 SD] - EchoStar8 77W TP 12 ConUS beam changed to Available
548 - HDPPV [MPEG4 HD] - Echostar6 72.7W TP 17 ConUS beam changed package flags (A)
625 - NHLN [MPEG2 SD] - EchoStar11 110W TP 15 ConUS beam changed package flags (A)
625 - NHLN [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
626 - NHL [MPEG2 SD] - EchoStar11 110W TP 16 ConUS beam changed package flags (A)
626 - NHL [MPEG4 SD] - Echostar6 72.7W TP 29 ConUS beam changed package flags (A)
627 - NHL [MPEG2 SD] - EchoStar11 110W TP 24 ConUS beam changed package flags (A)
627 - NHL [MPEG4 SD] - Echostar6 72.7W TP 29 ConUS beam changed package flags (A)
628 - NHL [MPEG2 SD] - EchoStar11 110W TP 24 ConUS beam changed package flags (A)
628 - NHL [MPEG4 SD] - Echostar6 72.7W TP 29 ConUS beam changed package flags (A)
629 - NHL [MPEG2 SD] - EchoStar7 119W TP 18 ConUS beam changed package flags (A)
629 - NHL [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
630 - NHL [MPEG2 SD] - EchoStar7 119W TP 16 ConUS beam changed package flags (A)
630 - NHL [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
631 - NHL [MPEG2 SD] - EchoStar7 119W TP 16 ConUS beam changed package flags (A)
631 - NHL [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
632 - NHL [MPEG2 SD] - EchoStar11 110W TP 24 ConUS beam changed package flags (A)
632 - NHL [MPEG4 SD] - Echostar6 72.7W TP 29 ConUS beam changed package flags (A)
633 - NHL [MPEG2 SD] - EchoStar7 119W TP 16 ConUS beam changed package flags (A)
633 - NHL [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
634 - NHL [MPEG2 SD] - EchoStar7 119W TP 16 ConUS beam changed package flags (A)
634 - NHL [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
635 - NHL [MPEG2 SD] - EchoStar7 119W TP 21 ConUS beam changed package flags (A)
635 - NHL [MPEG4 SD] - Echostar6 72.7W TP 01 ConUS beam changed package flags (A)
636 - NHL [MPEG2 SD] - EchoStar11 110W TP 16 ConUS beam changed package flags (A)
636 - NHL [MPEG4 SD] - Echostar6 72.7W TP 03 ConUS beam changed package flags (A)
637 - NHL [MPEG2 SD] - EchoStar7 119W TP 18 ConUS beam changed package flags (A)
637 - NHL [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
638 - NHL [MPEG2 SD] - EchoStar7 119W TP 18 ConUS beam changed package flags (A)
638 - NHL [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
639 - NHL [MPEG2 SD] - EchoStar7 119W TP 21 ConUS beam changed package flags (A)
639 - NHL [MPEG4 SD] - Echostar6 72.7W TP 01 ConUS beam changed package flags (A)
9405 - PNTGN [MPEG2 SD] - Ciel-2 129W TP 21 ConUS beam changed to Available (H)
9406 - ARTS [MPEG2 SD] - Ciel-2 129W TP 21 ConUS beam changed to Available (H)
9541(625) - NHLN [MPEG4 HD] - Ciel-2 129W TP 30 ConUS beam changed package flags (A)
9541(625) - NHLN [MPEG4 HD] - EchoStar3 61.5W TP 02 ConUS beam changed package flags (A)
9542(626) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 27 ConUS beam changed package flags (A)
9542(626) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9543(627) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9543(627) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9544(628) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9544(628) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9545(629) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9545(629) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 20 ConUS beam changed package flags (A)
9546(630) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9546(630) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9547(631) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9547(631) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 20 ConUS beam changed package flags (A)
9548(632) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9548(632) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9549(633) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 27 ConUS beam changed package flags (A)
9549(633) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9550(634) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 27 ConUS beam changed package flags (A)
9550(634) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9551(635) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9551(635) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 20 ConUS beam changed package flags (A)
9552(636) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9552(636) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9553(637) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9553(637) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 20 ConUS beam changed package flags (A)
9554(638) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9554(638) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 20 ConUS beam changed package flags (A)
9555(639) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 27 ConUS beam changed package flags (A)
9555(639) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 20 ConUS beam changed package flags (A)
Channel Mapdown Changes:
155 - NFLRZ EchoStar11 110W TP 16 ConUS beam mapdown of 82 added (A)
155 - NFLRZ Echostar6 72.7W TP 09 ConUS beam mapdown of 82 added (A)
Channel Renames:
8623(45) - KHCV - EchoStar7 119W TP 03 Spotbeam 3 renamed to KPST (A) (H)(Seattle, WA-ONE)
14840 - KHCV1 - EchoStar7 119W TP 03 Spotbeam 3 renamed to KPST1 (NA)
14997 - KHCV3 - EchoStar7 119W TP 03 Spotbeam 3 renamed to KPST3 (NA)
15044 - KHCV4 - EchoStar7 119W TP 03 Spotbeam 3 renamed to KPST4 (NA)
15049 - KHCV5 - EchoStar7 119W TP 03 Spotbeam 3 renamed to KPST5 (NA)
169 - NOGIN - EchoStar7 119W TP 14 ConUS beam renamed to NKJR (A)
169 - NOGIN - Echostar6 72.7W TP 05 ConUS beam renamed to NKJR (A)
181 - N - EchoStar11 110W TP 11 ConUS beam renamed to TNCK (A)
181 - N - Echostar6 72.7W TP 11 ConUS beam renamed to TNCK (A)
371 - BETJ - Ciel-2 129W TP 29 ConUS beam renamed to CTRC (A)
371 - BETJ - EchoStar3 61.5W TP 16 ConUS beam renamed to CTRC (A)
9645(99) - SNEAK - EchoStar11 110W TP 10 ConUS beam renamed to ITV (A)
9645(99) - SNEAK - EchoStar8 77W TP 29 ConUS beam renamed to ITV (A)
Transponder Changes:
EchoStar7 119W TP 10 ConUS beam 20000 QPSK 5/6 removed
Ciel-2 129W TP 09 Spotbeam 1 changed from 26000 QPSK 2/3 to 21500 8PSK 2/3
Channels in the system: 6631
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Channel Additions:
Channel Removals:
Channel Moves:
Channel Renames:
