9/30/2009 1:40pm - Uplink Activity Report - 148 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 9/30/2009 1:40pm - 148 changes
Uplink Comparison Range: 09/30/2009 01:24P - 09/30/2009 01:40P
Channel Additions:
141 - ESPNU [MPEG2 SD] added to EchoStar7 119W TP 04 ConUS beam (A) (H)
141 - ESPNU [MPEG4 SD] added to Echostar6 72.7W TP 23 ConUS beam (A) (H)
531 - PPV [MPEG2 SD] added to EchoStar11 110W TP 10 ConUS beam (NA)
533 - PPV [MPEG2 SD] added to EchoStar7 119W TP 16 ConUS beam (NA)
534 - $1.99 [MPEG2 SD] added to EchoStar11 110W TP 06 ConUS beam (A)
534 - $1.99 [MPEG4 SD] added to EchoStar8 77W TP 12 ConUS beam (A)
549 - HDPPV [MPEG4 HD] added to EchoStar11 110W TP 13 ConUS beam (A)
549 - HDPPV [MPEG4 HD] added to Echostar6 72.7W TP 17 ConUS beam (A)
651 - CLRS [MPEG2 SD] added to EchoStar3 61.5W TP 10 ConUS beam (NA)
856 - UTLSM [MPEG2 SD] added to EchoStar11 110W TP 16 ConUS beam (NA)
6085 - HISTI [MPEG2 SD] added to EchoStar11 110W TP 01 ConUS beam (NA)
6085 - HISTI [MPEG4 SD] added to Echostar6 72.7W TP 11 ConUS beam (NA)
6086 - BIO [MPEG2 SD] added to EchoStar11 110W TP 05 ConUS beam (NA)
6086 - BIO [MPEG4 SD] added to Echostar6 72.7W TP 03 ConUS beam (NA)
6087 - BIO [MPEG4 HD] added to Ciel-2 129W TP 29 ConUS beam (NA)
6087 - BIO [MPEG4 HD] added to EchoStar3 61.5W TP 16 ConUS beam (NA)
6088 - HMC [MPEG2 SD] added to EchoStar11 110W TP 01 ConUS beam (NA)
6088 - HMC [MPEG4 SD] added to Echostar6 72.7W TP 01 ConUS beam (NA)
6089 - HMC [MPEG4 HD] added to Ciel-2 129W TP 29 ConUS beam (NA)
6089 - HMC [MPEG4 HD] added to EchoStar3 61.5W TP 16 ConUS beam (NA)
6090 - ID [MPEG2 SD] added to EchoStar11 110W TP 09 ConUS beam (NA)
6090 - ID [MPEG4 SD] added to Echostar6 72.7W TP 03 ConUS beam (NA)
6091 - VS. [MPEG2 SD] added to EchoStar11 110W TP 21 ConUS beam (NA)
6091 - VS. [MPEG4 SD] added to Echostar6 72.7W TP 05 ConUS beam (NA)
6092 - VS. [MPEG4 HD] added to Ciel-2 129W TP 29 ConUS beam (NA)
6092 - VS. [MPEG4 HD] added to EchoStar3 61.5W TP 16 ConUS beam (NA)
6093 - GAC [MPEG2 SD] added to EchoStar11 110W TP 11 ConUS beam (NA)
6093 - GAC [MPEG4 SD] added to Echostar6 72.7W TP 05 ConUS beam (NA)
6094 - FUSE [MPEG2 SD] added to EchoStar7 119W TP 02 ConUS beam (NA)
6094 - FUSE [MPEG4 SD] added to Echostar6 72.7W TP 05 ConUS beam (NA)
6095 - WE [MPEG2 SD] added to EchoStar7 119W TP 12 ConUS beam (NA)
6095 - WE [MPEG4 SD] added to Echostar6 72.7W TP 15 ConUS beam (NA)
6096 - IFC [MPEG2 SD] added to EchoStar7 119W TP 06 ConUS beam (NA)
6096 - IFC [MPEG4 SD] added to Echostar6 72.7W TP 15 ConUS beam (NA)
6097 - CI [MPEG4 HD] added to EchoStar11 110W TP 19 ConUS beam (NA)
6097 - CI [MPEG4 HD] added to EchoStar8 77W TP 13 ConUS beam (NA)
6098 - AMC [MPEG2 SD] added to EchoStar7 119W TP 08 ConUS beam (NA)
6098 - AMC [MPEG4 SD] added to Echostar6 72.7W TP 09 ConUS beam (NA)
6099 - LMN [MPEG2 SD] added to EchoStar11 110W TP 02 ConUS beam (NA)
6099 - LMN [MPEG4 SD] added to Echostar6 72.7W TP 09 ConUS beam (NA)
6100 - LMN [MPEG4 HD] added to Ciel-2 129W TP 23 ConUS beam (NA)
6100 - LMN [MPEG4 HD] added to EchoStar3 61.5W TP 20 ConUS beam (NA)
9374(2) - KUNW [MPEG2 SD] added to EchoStar10 110W TP 12 Spotbeam 45 (NA)
9483(82) - NFLRZ [MPEG4 HD] added to Ciel-2 129W TP 27 ConUS beam (A)
9483(82) - NFLRZ [MPEG4 HD] added to EchoStar3 61.5W TP 20 ConUS beam (A)
Channel Removals:
14089 - KSCI6 (NA) removed from EchoStar7 119W TP 01 Spotbeam 5
14843 - KPXJ4 (NA) removed from EchoStar10 110W TP 18 Spotbeam 15
14662 - KMIZ4 (NA) removed from EchoStar10 110W TP 26 Spotbeam 19
14237 - WIVB3 (NA) removed from EchoStar10 110W TP 27 Spotbeam 09
14240 - WNLO2 (NA) removed from EchoStar10 110W TP 27 Spotbeam 09
14578 - WKBW2 (NA) removed from EchoStar10 110W TP 27 Spotbeam 09
15200 - WKBW3 (NA) removed from EchoStar10 110W TP 27 Spotbeam 09
15123 - WLIW4 (NA) removed from EchoStar10 110W TP 20 Spotbeam 04
14831 - WPGH2 (NA) removed from EchoStar10 110W TP 29 Spotbeam 09
5104 - KEVN (A) (H) removed from EchoStar7 119W TP 10 ConUS beam(Rapid City, SD-FOX)
5135 - KFNB (A) (H) removed from EchoStar7 119W TP 10 ConUS beam(Casper, WY-FOX)
141 - ESPNA (A) removed from EchoStar11 110W TP 24 ConUS beam
141 - ESPNA (A) removed from Echostar6 72.7W TP 29 ConUS beam
533 - $1.99 (A) removed from EchoStar11 110W TP 06 ConUS beam
533 - $1.99 (A) removed from EchoStar8 77W TP 12 ConUS beam
534 - HDPPV (A) removed from Ciel-2 129W TP 31 ConUS beam
534 - HDPPV (A) removed from Echostar6 72.7W TP 17 ConUS beam
Channel Moves:
8416 - KPXD [MPEG4 SD] moved from Echostar12 61.5W TP 15 Spotbeam 17 to Echostar12 61.5W TP 01 Spotbeam 16 (A) (H)(Arlington, TX-N/A)
8411 - KXTX [MPEG4 SD] moved from Echostar12 61.5W TP 15 Spotbeam 17 to Echostar12 61.5W TP 01 Spotbeam 16 (A) (H)(Dallas, TX-N/A)
8410 - KSTR [MPEG4 SD] moved from Echostar12 61.5W TP 15 Spotbeam 17 to Echostar12 61.5W TP 01 Spotbeam 16 (A) (H)(Irving, TX-TLF)
548 - HDPPV [MPEG4 HD] moved from EchoStar11 110W TP 13 ConUS beam to Ciel-2 129W TP 31 ConUS beam (A)
Channel Package Flag Changes:
7058(31) - KDCU [MPEG2 SD] - EchoStar10 110W TP 29 Spotbeam 29 changed to Available (H)(Derby, KS-UNI)
230 - ICTV [MPEG4 SD] - EchoStar8 77W TP 12 ConUS beam changed to Available
548 - HDPPV [MPEG4 HD] - Echostar6 72.7W TP 17 ConUS beam changed package flags (A)
625 - NHLN [MPEG2 SD] - EchoStar11 110W TP 15 ConUS beam changed package flags (A)
625 - NHLN [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
626 - NHL [MPEG2 SD] - EchoStar11 110W TP 16 ConUS beam changed package flags (A)
626 - NHL [MPEG4 SD] - Echostar6 72.7W TP 29 ConUS beam changed package flags (A)
627 - NHL [MPEG2 SD] - EchoStar11 110W TP 24 ConUS beam changed package flags (A)
627 - NHL [MPEG4 SD] - Echostar6 72.7W TP 29 ConUS beam changed package flags (A)
628 - NHL [MPEG2 SD] - EchoStar11 110W TP 24 ConUS beam changed package flags (A)
628 - NHL [MPEG4 SD] - Echostar6 72.7W TP 29 ConUS beam changed package flags (A)
629 - NHL [MPEG2 SD] - EchoStar7 119W TP 18 ConUS beam changed package flags (A)
629 - NHL [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
630 - NHL [MPEG2 SD] - EchoStar7 119W TP 16 ConUS beam changed package flags (A)
630 - NHL [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
631 - NHL [MPEG2 SD] - EchoStar7 119W TP 16 ConUS beam changed package flags (A)
631 - NHL [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
632 - NHL [MPEG2 SD] - EchoStar11 110W TP 24 ConUS beam changed package flags (A)
632 - NHL [MPEG4 SD] - Echostar6 72.7W TP 29 ConUS beam changed package flags (A)
633 - NHL [MPEG2 SD] - EchoStar7 119W TP 16 ConUS beam changed package flags (A)
633 - NHL [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
634 - NHL [MPEG2 SD] - EchoStar7 119W TP 16 ConUS beam changed package flags (A)
634 - NHL [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
635 - NHL [MPEG2 SD] - EchoStar7 119W TP 21 ConUS beam changed package flags (A)
635 - NHL [MPEG4 SD] - Echostar6 72.7W TP 01 ConUS beam changed package flags (A)
636 - NHL [MPEG2 SD] - EchoStar11 110W TP 16 ConUS beam changed package flags (A)
636 - NHL [MPEG4 SD] - Echostar6 72.7W TP 03 ConUS beam changed package flags (A)
637 - NHL [MPEG2 SD] - EchoStar7 119W TP 18 ConUS beam changed package flags (A)
637 - NHL [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
638 - NHL [MPEG2 SD] - EchoStar7 119W TP 18 ConUS beam changed package flags (A)
638 - NHL [MPEG4 SD] - Echostar6 72.7W TP 19 ConUS beam changed package flags (A)
639 - NHL [MPEG2 SD] - EchoStar7 119W TP 21 ConUS beam changed package flags (A)
639 - NHL [MPEG4 SD] - Echostar6 72.7W TP 01 ConUS beam changed package flags (A)
9405 - PNTGN [MPEG2 SD] - Ciel-2 129W TP 21 ConUS beam changed to Available (H)
9406 - ARTS [MPEG2 SD] - Ciel-2 129W TP 21 ConUS beam changed to Available (H)
9541(625) - NHLN [MPEG4 HD] - Ciel-2 129W TP 30 ConUS beam changed package flags (A)
9541(625) - NHLN [MPEG4 HD] - EchoStar3 61.5W TP 02 ConUS beam changed package flags (A)
9542(626) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 27 ConUS beam changed package flags (A)
9542(626) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9543(627) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9543(627) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9544(628) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9544(628) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9545(629) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9545(629) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 20 ConUS beam changed package flags (A)
9546(630) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9546(630) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9547(631) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9547(631) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 20 ConUS beam changed package flags (A)
9548(632) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9548(632) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9549(633) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 27 ConUS beam changed package flags (A)
9549(633) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9550(634) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 27 ConUS beam changed package flags (A)
9550(634) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9551(635) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9551(635) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 20 ConUS beam changed package flags (A)
9552(636) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9552(636) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 30 ConUS beam changed package flags (A)
9553(637) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9553(637) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 20 ConUS beam changed package flags (A)
9554(638) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 25 ConUS beam changed package flags (A)
9554(638) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 20 ConUS beam changed package flags (A)
9555(639) - NHLHD [MPEG4 HD] - Ciel-2 129W TP 27 ConUS beam changed package flags (A)
9555(639) - NHLHD [MPEG4 HD] - EchoStar3 61.5W TP 20 ConUS beam changed package flags (A)
Channel Mapdown Changes:
155 - NFLRZ EchoStar11 110W TP 16 ConUS beam mapdown of 82 added (A)
155 - NFLRZ Echostar6 72.7W TP 09 ConUS beam mapdown of 82 added (A)
Channel Renames:
8623(45) - KHCV - EchoStar7 119W TP 03 Spotbeam 3 renamed to KPST (A) (H)(Seattle, WA-ONE)
14840 - KHCV1 - EchoStar7 119W TP 03 Spotbeam 3 renamed to KPST1 (NA)
14997 - KHCV3 - EchoStar7 119W TP 03 Spotbeam 3 renamed to KPST3 (NA)
15044 - KHCV4 - EchoStar7 119W TP 03 Spotbeam 3 renamed to KPST4 (NA)
15049 - KHCV5 - EchoStar7 119W TP 03 Spotbeam 3 renamed to KPST5 (NA)
169 - NOGIN - EchoStar7 119W TP 14 ConUS beam renamed to NKJR (A)
169 - NOGIN - Echostar6 72.7W TP 05 ConUS beam renamed to NKJR (A)
181 - N - EchoStar11 110W TP 11 ConUS beam renamed to TNCK (A)
181 - N - Echostar6 72.7W TP 11 ConUS beam renamed to TNCK (A)
371 - BETJ - Ciel-2 129W TP 29 ConUS beam renamed to CTRC (A)
371 - BETJ - EchoStar3 61.5W TP 16 ConUS beam renamed to CTRC (A)
9645(99) - SNEAK - EchoStar11 110W TP 10 ConUS beam renamed to ITV (A)
9645(99) - SNEAK - EchoStar8 77W TP 29 ConUS beam renamed to ITV (A)
Transponder Changes:
EchoStar7 119W TP 10 ConUS beam 20000 QPSK 5/6 removed
Ciel-2 129W TP 09 Spotbeam 1 changed from 26000 QPSK 2/3 to 21500 8PSK 2/3
Channels in the system: 6631
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Dish is teasing ESPNU HD on its twitter account saying...
"Any updates on this one and i'll keep ya posted RT @RadioDaniel @DishNetwork How about ESPNU HD ;)"
What is this? Clinical Trials Research Center? Colorado Therapeutic Riding Center? California Trolley and Railroad Corporation? (actual results of google for CRTC) :)
or just some Crappy Trashy Repulsive musiC channel.
On Absolute I am noW getting ESPNU SD and Style SD (despite the fact that neither are free previews this month) however, ESPNU is still showing up on 148...
I suspect the name stands for Cable Television Rap Channel. The programming on CTRC right now pretty much looks like what was on BET J prior to the name change. I suspect tomorrow, the channel will be programming something different. Noggin is now branded as Nick Jr. and N and now branded as Nick Teen; making the change before tomorrow.
CRTC is the Canadian Radio Television Telecommunication Commission. At first glance it looked like something Canadian, but alas no. Though it would be nice to have CBC, Global or Canada TV (CTV).
Welcome additions are the Pentagon and Arts Channels. Though, they added another 24 hour infomercial channel on channel 230. And, ESPNU now shows up on both 141 and 148.
The following internationals @ 118 satellite also went into free preview today but didnt see them mentioned here;
679
680
681
697
708
D
10/1/2009 11:26pm - Uplink Activity Report - 8 changes
D
10/6/2009 6:40pm - Uplink Activity Report - 2 changes
