10/22/2009 2:11am - Uplink Activity Report - 85 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 10/22/2009 2:11am - 85 changes
Uplink Comparison Range: 10/22/2009 01:55A - 10/22/2009 02:11A
Channel Additions:
36610 - ACTVT [161] added to Nimiq5 72.7W TP 21 ConUS beam (A)
Channel Removals:
6085 - HISTI (NA) removed from EchoStar11 110W TP 01 ConUS beam
6085 - HISTI (NA) removed from Nimiq5 72.7W TP 11 ConUS beam
6086 - BIO (NA) removed from EchoStar11 110W TP 05 ConUS beam
6086 - BIO (NA) removed from Nimiq5 72.7W TP 03 ConUS beam
6087 - BIO (NA) removed from Ciel-2 129W TP 29 ConUS beam
6087 - BIO (NA) removed from EchoStar3 61.5W TP 16 ConUS beam
6088 - HMC (NA) removed from EchoStar11 110W TP 01 ConUS beam
6088 - HMC (NA) removed from Nimiq5 72.7W TP 01 ConUS beam
6089 - HMC (NA) removed from Ciel-2 129W TP 29 ConUS beam
6089 - HMC (NA) removed from EchoStar3 61.5W TP 16 ConUS beam
6090 - ID (NA) removed from EchoStar11 110W TP 09 ConUS beam
6090 - ID (NA) removed from Nimiq5 72.7W TP 03 ConUS beam
6091 - VS. (NA) removed from EchoStar11 110W TP 21 ConUS beam
6091 - VS. (NA) removed from Nimiq5 72.7W TP 05 ConUS beam
6092 - VS. (NA) removed from Ciel-2 129W TP 29 ConUS beam
6092 - VS. (NA) removed from EchoStar3 61.5W TP 16 ConUS beam
6093 - GAC (NA) removed from EchoStar11 110W TP 11 ConUS beam
6093 - GAC (NA) removed from Nimiq5 72.7W TP 05 ConUS beam
6094 - FUSE (NA) removed from EchoStar7 119W TP 02 ConUS beam
6094 - FUSE (NA) removed from Nimiq5 72.7W TP 05 ConUS beam
6095 - WE (NA) removed from EchoStar7 119W TP 12 ConUS beam
6095 - WE (NA) removed from Nimiq5 72.7W TP 15 ConUS beam
6096 - IFC (NA) removed from EchoStar7 119W TP 06 ConUS beam
6096 - IFC (NA) removed from Nimiq5 72.7W TP 15 ConUS beam
6097 - CI (NA) removed from EchoStar11 110W TP 19 ConUS beam
6097 - CI (NA) removed from EchoStar8 77W TP 13 ConUS beam
6098 - AMC (NA) removed from EchoStar7 119W TP 08 ConUS beam
6098 - AMC (NA) removed from Nimiq5 72.7W TP 09 ConUS beam
6099 - LMN (NA) removed from EchoStar11 110W TP 02 ConUS beam
6099 - LMN (NA) removed from Nimiq5 72.7W TP 09 ConUS beam
6100 - LMN (NA) removed from Ciel-2 129W TP 23 ConUS beam
6100 - LMN (NA) removed from EchoStar3 61.5W TP 20 ConUS beam
Channel Moves:
119 - BIO [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 07 ConUS beam (A)
173 - DISW [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 07 ConUS beam (A)
192 - ID [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 07 ConUS beam (A)
204 - TRU [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 07 ConUS beam (A)
205 - FXNWS [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 07 ConUS beam (A)
207 - CNBCW [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 07 ConUS beam (A)
209 - MSNBC [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 07 ConUS beam (A)
261 - EWTN [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 01 ConUS beam (A)
302 - HBOSG [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 01 ConUS beam (A)
304 - HBO2W [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 01 ConUS beam (A)
311 - MAX-W [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
329 - TMC-W [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
330 - TMCXW [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
340 - ENCOR [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
351 - STRZW [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
387 - CI [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A)
401 - GOLF [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A)
409 - CSNCA [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 09 ConUS beam (A) (H)
411 - PRIME [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 01 ConUS beam (A) (H)
437 - SPSOU [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 01 ConUS beam (A) (H)
546 - HDPPV [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to Nimiq5 72.7W TP 27 ConUS beam (A)
547 - HDPPV [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to Nimiq5 72.7W TP 27 ConUS beam (A)
548 - HDPPV [MPEG4 HD] moved from Nimiq5 72.7W TP 17 ConUS beam to Nimiq5 72.7W TP 27 ConUS beam (A)
549 - HDPPV [MPEG4 HD] moved from Nimiq5 72.7W TP 17 ConUS beam to Nimiq5 72.7W TP 27 ConUS beam (A)
4152 - CBS C [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A) (H)
4194 - GREEN [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A) (H)
4239 - WGN [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A) (H)
4287 - CI [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A) (H)
5327 - WGN [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A) (H)
9417 - EWTN [MPEG4 SD] moved from Nimiq5 72.7W TP 03 ConUS beam to Nimiq5 72.7W TP 01 ConUS beam (A) (H)
9446 - WGN [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A)
9457 - GREEN [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A)
9465 - MAVHD [MPEG4 HD] moved from Nimiq5 72.7W TP 17 ConUS beam to Nimiq5 72.7W TP 27 ConUS beam (A)
9481 - TMC-E [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A)
9495 - CBS C [MPEG4 HD] moved from EchoStar8 77W TP 13 ConUS beam to Nimiq5 72.7W TP 17 ConUS beam (A)
9496 - SEDGE [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to Nimiq5 72.7W TP 13 ConUS beam (A) (H)
9498 - STRZW [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to Nimiq5 72.7W TP 13 ConUS beam (A) (H)
9505 - ENCOR [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to Nimiq5 72.7W TP 13 ConUS beam (A) (H)
9531 - DNFYI [MPEG4 HD] moved from Nimiq5 72.7W TP 17 ConUS beam to Nimiq5 72.7W TP 27 ConUS beam (A)
Transponder Changes:
Nimiq5 72.7W TP 03 ConUS beam 20000 QPSK 5/6 removed
Nimiq5 72.7W TP 05 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 11 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 13 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 15 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 17 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 19 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 23 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 25 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 27 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 29 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 31 ConUS beam changed from 20000 QPSK 5/6 to 21500 8PSK 2/3
EchoStar8 77W TP 32 ConUS beam 20000 QPSK 5/6 removed
Channels in the system: 6608
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
shuffle shuffle shuffle, move move move... Looks like they are busy playing with their new satellite. More TPs going 8PSK, they are going to have a *lot* of capacity at this location. Especially when when DIRECTV starts to hand over the even TPs.
Looks like they moved a lot of channels off of 77 sat and consolidated them on 72.7 sat because of the bandwith savings from switching to 8psk. Now that would leave a lot more space on 77 for something else:Locals?
I see that. But they took channel of the other Satellites like 110 and 61.5. I hope I didn't loose these channels now. Like Hist, VS & all those ones. I have 110, 119 & 61.5. They removed stuff from those satellite in this uplink.
Josh
Josh
Those 6000's shouldn't affect you at all. If they were the 94xx range that would be a different story.
Might swing my Dish300 over there to check things out since I haven't bolted my FTA dish to my slab on the back side of the house yet. I suspect we will see more consolidation over the next few days, looks like everything is doing fine with this bird...awesome!
Wonder if they were "test" channels or part of a forgotten package. Everything being dropped is in the 6000's, are there any packages that have national cable networks and get the channels in the 6000's?
What is the 6000 range for? Why did they remove all those channels?
Thanks,
Josh
Thanks,
Josh
I'm not sure what they were for, I don't recall anyone seeing them on their receiver. They were simply duplicates numbers mapped to same video streams. Technically they didn't remove the channels themselves, just the duplicated numbers in the mapping. Nothing to worry about...
Don't know of any programming packs that have history international, bio, hallmark movie channel, id, vs, gac, we, fuse, ifc, ci, amc, lifetime movie net as their line up.
actually if that was a "welcome pack 'B'" it's really not a bad line up.
if you want to speculate: I think all of the rainbow channels are listed there. perhaps they were anticipating a rainbow take down and the other (non-rainbow) channels listed would have been used to take their place during a dispute?? Dispute's averted no need to keep the placeholders in tact? = again just WILD SPECULATION not tied to any proof whatsoever...
D
10/22/2009 4:10am - Uplink Activity Report - 4 changes
D
10/21/2009 1:00pm - Uplink Activity Report - 68 changes
