11/18/2009 3:51pm - Uplink Activity Report - 47 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 11/18/2009 3:51pm - 47 changes
Uplink Comparison Range: 11/18/2009 03:30P - 11/18/2009 03:50P
Channel Additions:
7503(29) - KHOG [MPEG2 SD] added to EchoStar10 110W TP 23 Spotbeam 20 (NA)(Fayetteville, AR-ABC)
8538(9) - KUSG [MPEG2 SD] added to EchoStar10 110W TP 23 Spotbeam 34 (NA)(St. George, UT-CBS)
218 - VERIA [MPEG2 SD] added to EchoStar11 110W TP 03 ConUS beam (A)
218 - VERIA [MPEG4 SD] added to Nimiq5 72.7W TP 31 ConUS beam (A)
220 - MERC [MPEG2 SD] added to EchoStar11 110W TP 10 ConUS beam (A)
292 - EPIX [MPEG2 SD] added to EchoStar11 110W TP 09 ConUS beam (NA)
292 - EPIX [MPEG4 SD] added to Nimiq5 72.7W TP 01 ConUS beam (NA)
785 - VKAIR [MPEG2 SD] added to Anik F3 118.7W TP 20 ConUS beam (NA)
786 - PEOPL [MPEG2 SD] added to Anik F3 118.7W TP 01 ConUS beam (NA)
947(91) - AUD20 [MPEG AUDIO] added to EchoStar8 77W TP 21 ConUS beam (A)
949(97) - MUZK2 [MPEG AUDIO] added to EchoStar8 77W TP 21 ConUS beam (A)
5745 - IAD14 [DATA] added to EchoStar11 110W TP 01 ConUS beam (NA)
5745 - IAD14 [DATA] added to Nimiq5 72.7W TP 11 ConUS beam (NA)
6155 - LTD18 [MPEG2 SD] added to EchoStar11 110W TP 06 ConUS beam (NA)
6801 - UPSD [MPEG2 SD] added to Anik F3 118.7W TP 11 ConUS beam (NA)
6802 - UP2 [MPEG2 SD] added to Anik F3 118.7W TP 18 ConUS beam (NA)
6803 - UP3 [MPEG2 SD] added to Anik F3 118.7W TP 21 ConUS beam (NA)
8398(16) - KOSAD [MPEG2 SD] added to EchoStar10 110W TP 12 Spotbeam 27 (NA)
9589 - LTD9 [MPEG4 SD] added to EchoStar3 61.5W TP 25 ConUS beam (NA)
Channel Removals:
5109 - KDNL (A) (H) removed from Anik F3 118.7W TP 11 ConUS beam(St.louis, MO-ABC)
5110 - KMOV (A) (H) removed from Anik F3 118.7W TP 11 ConUS beam(St.louis, MO-CBS)
5111 - KSDK (A) (H) removed from Anik F3 118.7W TP 18 ConUS beam(St.louis, MO-NBC)
5112 - KTVI (A) (H) removed from Anik F3 118.7W TP 18 ConUS beam(St.louis, MO-FOX)
6457 - KPLR (A) (H) removed from Anik F3 118.7W TP 21 ConUS beam(St.louis, MO-CW)
218 - MERC (A) removed from EchoStar11 110W TP 10 ConUS beam
233 - NOTAX (NA) removed from EchoStar11 110W TP 01 ConUS beam
573 - NBALP (A) (H) removed from EchoStar11 110W TP 06 ConUS beam
573 - NBALP (A) (H) removed from EchoStar3 61.5W TP 25 ConUS beam
9578 - LTD10 (NA) removed from EchoStar11 110W TP 09 ConUS beam
Channel Moves:
125 - ITV2 [MPEG4 SD] moved from EchoStar3 61.5W TP 10 ConUS beam to Nimiq5 72.7W TP 11 ConUS beam (A)
19215 - HUNTT [DATA] moved from EchoStar11 110W TP 09 ConUS beam to EchoStar11 110W TP 14 ConUS beam (A)
19216 - HUNTV [DATA] moved from EchoStar11 110W TP 09 ConUS beam to EchoStar11 110W TP 14 ConUS beam (A)
Channel Package Flag Changes:
5274(38) - WNOL [MPEG4 HD] - Ciel-2 129W TP 10 Spotbeam 50 changed to Available (H)(New Orleans, LA-CW)
125 - ITV2 [MPEG2 SD] - EchoStar11 110W TP 01 ConUS beam changed to Available
617 - ZCINE [MPEG2 SD] - EchoStar3 61.5W TP 14 ConUS beam changed package flags (A)
703 - FTVTW [MPEG2 SD] - Anik F3 118.7W TP 29 ConUS beam changed to Available (H)
790 - ZCINE [MPEG2 SD] - Anik F3 118.7W TP 27 ConUS beam changed package flags (A)
803 - UDAYA [MPEG2 SD] - Anik F3 118.7W TP 17 ConUS beam changed package flags (A)
947(91) - AUD20 [MPEG AUDIO] - EchoStar7 119W TP 12 ConUS beam changed package flags (A)
949(97) - MUZK2 [MPEG AUDIO] - EchoStar7 119W TP 12 ConUS beam changed package flags (A)
4327 - SPIKE [MPEG4 HD] - Ciel-2 129W TP 07 Spotbeam 1 changed package flags (A)
4391 - SPIKE [MPEG4 HD] - Ciel-2 129W TP 04 Spotbeam 55 changed package flags (A)
6525(19) - WZMQ [MPEG2 SD] - Ciel-2 129W TP 12 Spotbeam 15 changed to Available (H)
Channel Mapdown Changes:
6003 - SIRI EchoStar7 119W TP 04 ConUS beam mapdown of 93 added (A)
6003 - SIRI Nimiq5 72.7W TP 05 ConUS beam mapdown of 93 added (A)
6004 - SIRI EchoStar7 119W TP 21 ConUS beam mapdown of 94 added (A)
6004 - SIRI Nimiq5 72.7W TP 15 ConUS beam mapdown of 94 added (A)
Channels in the system: 6636
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Yes EPIX HD is uplinked, it is on TMP65 which is on channel 4835 which is coming off of both 129 and 61.5.
The reason its not listed in the uplink is because the channel was already uplinked with the TMP65 name. :)
Anyone heard anything about Quad Cities HD Locals?
I know they were delayed (when they were supposed to go live last week), but just curious if anyone knows why, or WHEN?
Scott that mean it's on air????
Sort off.
It appears that the SD and HD channels now have data on them. So its on the air for the Dish techs at the uplink.
However at this time it is not available to customers. We dont know when (or ven if) it will be turned on to customers.
There have been times in the past a channel was uplinked but was never made available to customers and later (sometimes month later) was removed form the uplink.
So we are close... how close is the question.
I figure if it was in Platinum it would be in the 300s channel range so maybe Classic Gold 250 instead.
I have 250 and wouldn't mind having another movie channel to go along with TMC and Encore channels.
D
1/13/2010 1:30pm - Uplink Activity Report - 32 changes
D
1/14/2010 5:29pm - Uplink Activity Report - 13 changes
