Separator 123254 to Multiswitch
Mogul12
Connecticut
I currently have two dual tuner, receivers hooked up to my satellite. I cannot get to the satellite since is is on the side of the chimney and I do no have a tall enough latter. I want to add more receivers, but I cannot run more lines to the satellite since my townhouse complex won't let me.
Currently there is a single line going to each receiver with a Separator model # 123254. Can I take the 2 outputs from the separator and go into a multiswitch, and then run multiple lines off of the multiswitch?
If not, how can I use this setup to split off to more receivers?
You can have two lines but you can't have four?
Usually it isn't your problem to make this happen. You call DISH and order the equipment and they set it up for you.
You could use a external switch (DPP44 or like) down near the sets but you would need 1 line per LNB, usually 3 if you have HD, and LNBs on the dish without a switch or ones that turns off with a downstream switch. I don't know the models. Differs with Legacy (that would have 4 or 6 lines), DP, and DPP. More info for the installers here, please.
-Ken
Echostar 15 Files with FCC for Launch
Just noticed....
