5/5/2010 5:02pm - Uplink Activity Report - 58 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 5/5/2010 5:02pm - 58 changes
Uplink Comparison Range: 05/05/2010 04:46P - 05/05/2010 05:01P
Channel Additions:
6425(49) - KPDX [MPEG4 HD] added to EchoStar10 110W TP 29 Spotbeam 44 (NA)(Vancouver, WA-MY)
125 - ITV2 [MPEG2 SD] added to EchoStar11 110W TP 10 ConUS beam (NA)
125 - ITV2 [MPEG4 SD] added to Nimiq5 72.7W TP 31 ConUS beam (NA)
212 - NASA [MPEG2 SD] added to EchoStar7 119W TP 04 ConUS beam (A)
212 - NASA [MPEG4 SD] added to Nimiq5 72.7W TP 21 ConUS beam (A)
295 - EARTH [MPEG2 SD] added to EchoStar11 110W TP 21 ConUS beam (A)
295 - EARTH [MPEG4 SD] added to Nimiq5 72.7W TP 15 ConUS beam (A)
653 - AFR24 [MPEG2 SD] added to Anik F3 118.7W TP 25 ConUS beam (NA)
656 - EBS [MPEG2 SD] added to Anik F3 118.7W TP 14 ConUS beam (NA)
667 - AFRMU [MPEG2 SD] added to Anik F3 118.7W TP 14 ConUS beam (NA)
842 - UTLSM [MPEG4 SD] added to EchoStar8 77W TP 12 ConUS beam (NA)
4275 - TMP43 [MPEG4 HD] added to Ciel-2 129W TP 32 ConUS beam (NA)
4275 - TMP43 [MPEG4 HD] added to Nimiq5 72.7W TP 06 ConUS beam (NA)
4276 - TMP44 [MPEG4 HD] added to Ciel-2 129W TP 32 ConUS beam (NA)
4276 - TMP44 [MPEG4 HD] added to Nimiq5 72.7W TP 06 ConUS beam (NA)
5347 - TMP43 [MPEG4 HD] added to Ciel-2 129W TP 32 ConUS beam (NA)
5347 - TMP43 [MPEG4 HD] added to Nimiq5 72.7W TP 06 ConUS beam (NA)
5348 - TMP44 [MPEG4 HD] added to Ciel-2 129W TP 32 ConUS beam (NA)
5348 - TMP44 [MPEG4 HD] added to Nimiq5 72.7W TP 06 ConUS beam (NA)
5371 - TMP39 [MPEG4 HD] added to Ciel-2 129W TP 32 ConUS beam (NA)
5371 - TMP39 [MPEG4 HD] added to Nimiq5 72.7W TP 06 ConUS beam (NA)
9644 - ITV2 [MPEG2 SD] added to EchoStar11 110W TP 10 ConUS beam (NA)
9644 - ITV2 [MPEG4 SD] added to Nimiq5 72.7W TP 31 ConUS beam (NA)
Channel Removals:
212 - EARTH (A) [MPEG2 SD] removed from EchoStar11 110W TP 21 ConUS beam
212 - EARTH (A) [MPEG4 SD] removed from Nimiq5 72.7W TP 15 ConUS beam
4870 - TP211 (NA) [MPEG4 HD] removed from EchoStar6 61.5W TP 26 ConUS beam
4871 - TP212 (NA) [MPEG4 HD] removed from EchoStar6 61.5W TP 26 ConUS beam
4872 - TP213 (NA) [MPEG4 HD] removed from EchoStar6 61.5W TP 26 ConUS beam
4873 - TP214 (NA) [MPEG4 HD] removed from EchoStar6 61.5W TP 26 ConUS beam
4874 - TP215 (NA) [MPEG4 HD] removed from EchoStar6 61.5W TP 26 ConUS beam
4875 - TP216 (NA) [MPEG4 HD] removed from EchoStar6 61.5W TP 26 ConUS beam
4876 - TP217 (NA) [MPEG4 HD] removed from EchoStar6 61.5W TP 26 ConUS beam
4877 - TP218 (NA) [MPEG4 HD] removed from EchoStar6 61.5W TP 26 ConUS beam
4878 - TP219 (NA) [MPEG4 HD] removed from EchoStar6 61.5W TP 26 ConUS beam
Channel Moves:
363 - INDIE [MPEG4 HD] moved from Ciel-2 129W TP 26 ConUS beam to EchoStar11 110W TP 09 ConUS beam (A)
363 - INDIE [MPEG4 HD] moved from Nimiq5 72.7W TP 32 ConUS beam to EchoStar3 61.5W TP 31 ConUS beam (A)
365 - RETRO [MPEG4 HD] moved from Ciel-2 129W TP 26 ConUS beam to EchoStar11 110W TP 09 ConUS beam (A)
365 - RETRO [MPEG4 HD] moved from Nimiq5 72.7W TP 32 ConUS beam to EchoStar3 61.5W TP 31 ConUS beam (A)
387 - CI [MPEG4 HD] moved from EchoStar11 110W TP 19 ConUS beam to EchoStar11 110W TP 09 ConUS beam (A)
387 - CI [MPEG4 HD] moved from Nimiq5 72.7W TP 17 ConUS beam to EchoStar3 61.5W TP 31 ConUS beam (A)
4861 - VCT1 [MPEG4 HD] moved from EchoStar6 61.5W TP 26 ConUS beam to EchoStar6 61.5W TP 28 ConUS beam (NA)
4862 - VCT2 [MPEG4 HD] moved from EchoStar6 61.5W TP 26 ConUS beam to EchoStar6 61.5W TP 28 ConUS beam (NA)
4863 - VCT3 [MPEG4 HD] moved from EchoStar6 61.5W TP 26 ConUS beam to EchoStar6 61.5W TP 28 ConUS beam (NA)
4864 - VCT4 [MPEG4 HD] moved from EchoStar6 61.5W TP 26 ConUS beam to EchoStar6 61.5W TP 28 ConUS beam (NA)
4865 - VCT5 [MPEG4 HD] moved from EchoStar6 61.5W TP 26 ConUS beam to EchoStar6 61.5W TP 28 ConUS beam (NA)
4866 - VCT6 [MPEG4 HD] moved from EchoStar6 61.5W TP 26 ConUS beam to EchoStar6 61.5W TP 28 ConUS beam (NA)
4867 - VCT7 [MPEG4 HD] moved from EchoStar6 61.5W TP 26 ConUS beam to EchoStar6 61.5W TP 28 ConUS beam (NA)
4868 - VCT8 [MPEG4 HD] moved from EchoStar6 61.5W TP 26 ConUS beam to EchoStar6 61.5W TP 28 ConUS beam (NA)
5773 - IAD4 [DATA] moved from Nimiq5 72.7W TP 07 ConUS beam to Nimiq5 72.7W TP 31 ConUS beam (A)
Channel Package Flag Changes:
5262(21) - WFMJ [MPEG4 HD] - Ciel-2 129W TP 08 Spotbeam 25 changed to Available (H)(Youngstown, OH-N/A)
577 - PFC [MPEG2 SD] - Anik F3 118.7W TP 20 ConUS beam changed package flags (A)
577 - PFC [MPEG2 SD] - EchoStar6 61.5W TP 04 ConUS beam changed package flags (A)
671 - TARAB [MPEG2 SD] - Anik F3 118.7W TP 23 ConUS beam changed package flags (A)
671 - TARAB [MPEG2 SD] - EchoStar3 61.5W TP 29 ConUS beam changed package flags (A)
19086 - LUDIV [DATA] - EchoStar11 110W TP 06 ConUS beam changed package flags (A)
19086 - LUDIV [DATA] - Nimiq5 72.7W TP 23 ConUS beam changed package flags (A)
Channel Renames:
8662(4) - WUNC(Chapel Hill, NC-PBS) - EchoStar7 119W TP 05 Spotbeam 14 renamed to WUNG (Concord, NC-PBS) (A) (H)
8662(4) - WUNC(Chapel Hill, NC-PBS) - Echostar12 61.5W TP 09 Spotbeam 8 renamed to WUNG (Concord, NC-PBS) (A) (H)
Channels in the system: 7051
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2010 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v10.05.04
© 2010 - All Rights Reserved - SatelliteGuys Incorporated
Well now there's a surprise. 3 channels moved off 129 and 72 and placed on 110 and Echo3 at 61.5.
It looks like we may be getting CSPAN3. DISH Earth moved to 295 and NASA took over DISH Earth's spot.
TMP43 and TMP44 look like HD versions of shopping/infomercial channels
The Indie and Retro moves are probably temporary, because these two channels are going to be removed from 363 and 365 respectively. The channel permanent locations are already operating on channels 378 and 379 respectively.
And of course the DISH Latino moves noted above.
anyone knows whats going on with RFDTVHD?is it still in testing i just checked in uplink reports and it is not there any help would be very appreciated.
Those TMPs do not match their 4xxx scheme...looks like they are toying with you guys now. Those are the 3 channels Scott mentioned yesterday.
Nice to see my new changes worked well on the local channel rename.
No, CSPN3 would logically go to 212, since 210 and 211 are CSPN and CSPN2. The INFO says it is happening on May 12th (one week from today).
The only reason to move NASA to 212 is for another Weather Channel that would then be contiguous with 214, or the most likely scenario is another NASA channel. There are several NASA channels on C-Band. One possibility is NASA-HD, which they would map down to 213, because the content is different from NASA-TV.
5370 is EPIX, so 5371 would logically be EPIX2.
The 270 channel range has two channels that a) are not shopping channels, b) have good relations with Dish and c) were just added by DirecTV in HD...
But if it's NASA, why don't they just tell us what they're doing? It shouldn't be a secret when the channels are public-domain. (Although Dish recently did a very stupid thing and encrypted NASA after having it in the clear forever.)
I am a little confused...I am on 61.5 and now I see indie and retro HD but they say they have moved...(I never had them in the first place)...and the channels they have moved to do not exist on any of my my lists ....do I still have to get an Eastern arc dish to see these and the rest of the new HD?
D
5/10/2010 3:05am - Uplink Activity Report - 8 changes
D
5/12/2010 3:07pm - Uplink Activity Report - 1 change
