5/19/2010 3:08am - Uplink Activity Report - 85 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 5/19/2010 3:08am - 85 changes
Uplink Comparison Range: 05/19/2010 02:45A - 05/19/2010 03:07A
Channel Removals:
6808 - UP9 (NA) [MPEG2 SD] removed from EchoStar14 119W TP 05 Spotbeam A27
6840 - UP8 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 04 Spotbeam A2
6847 - UP11 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 04 Spotbeam B18
6855 - UP10 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 04 Spotbeam A5
6862 - UP10 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 01 Spotbeam A24
6877 - UP29 (NA) [MPEG4 HD] removed from EchoStar14 119W TP 04 Spotbeam B12
Channel Moves:
7030 - KIMO [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 2 to EchoStar14 119W TP 01 Spotbeam A24 (A) (H)(Anchorage, AK-ABC)
7031 - KTVA [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 2 to EchoStar14 119W TP 01 Spotbeam A24 (A) (H)(Anchorage, AK-CBS)
7032 - KTUU [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 2 to EchoStar14 119W TP 01 Spotbeam A24 (A) (H)(Anchorage, AK-NBC)
7033 - KTBY [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 2 to EchoStar14 119W TP 01 Spotbeam A24 (A) (H)(Anchorage, AK-FOX)
7035 - KYES [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 2 to EchoStar14 119W TP 01 Spotbeam A24 (A) (H)(Anchorage, AK-MNT)
7036 - KAKM [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 2 to EchoStar14 119W TP 01 Spotbeam A24 (A) (H)(Anchorage, AK-PBS)
7037 - KYESD [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 2 to EchoStar14 119W TP 01 Spotbeam A24 (A) (H)(Anchorage, AK-N/A)
7038 - KDMD [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 2 to EchoStar14 119W TP 01 Spotbeam A24 (A) (H)(Anchorage, AK-IND)
8957 - KUVE [MPEG2 SD] moved from EchoStar7 119W TP 05 Spotbeam 6 to EchoStar14 119W TP 04 Spotbeam A5 (A) (H)(Green Valley, AZ-UNI)
8954 - KWBA [MPEG2 SD] moved from EchoStar7 119W TP 05 Spotbeam 6 to EchoStar14 119W TP 04 Spotbeam A5 (A) (H)(Sierra Vista, AZ-CW)
8950 - KGUN [MPEG2 SD] moved from EchoStar7 119W TP 05 Spotbeam 6 to EchoStar14 119W TP 04 Spotbeam A5 (A) (H)(Tucson, AZ-ABC)
8951 - KOLD [MPEG2 SD] moved from EchoStar7 119W TP 05 Spotbeam 6 to EchoStar14 119W TP 04 Spotbeam A5 (A) (H)(Tucson, AZ-CBS)
8952 - KVOA [MPEG2 SD] moved from EchoStar7 119W TP 05 Spotbeam 6 to EchoStar14 119W TP 04 Spotbeam A5 (A) (H)(Tucson, AZ-NBC)
8953 - KMSB [MPEG2 SD] moved from EchoStar7 119W TP 05 Spotbeam 6 to EchoStar14 119W TP 04 Spotbeam A5 (A) (H)(Tucson, AZ-FOX)
8955 - KTTU [MPEG2 SD] moved from EchoStar7 119W TP 05 Spotbeam 6 to EchoStar14 119W TP 04 Spotbeam A5 (A) (H)(Tucson, AZ-MY)
8956 - KUAT [MPEG2 SD] moved from EchoStar7 119W TP 05 Spotbeam 6 to EchoStar14 119W TP 04 Spotbeam A5 (A) (H)(Tucson, AZ-PBS)
8958 - KHRR [MPEG2 SD] moved from EchoStar7 119W TP 05 Spotbeam 6 to EchoStar14 119W TP 04 Spotbeam A5 (A) (H)(Tucson, AZ-TEL)
8959 - KUDF [MPEG2 SD] moved from EchoStar7 119W TP 05 Spotbeam 6 to EchoStar14 119W TP 04 Spotbeam A5 (A) (H)(Tucson, AZ-AZT)
6441 - KTVU [MPEG4 HD] moved from EchoStar7 119W TP 07 Spotbeam 4 to EchoStar14 119W TP 04 Spotbeam A2 (A) (H)(Oakland, CA-FOX)
6438 - KGO [MPEG4 HD] moved from EchoStar7 119W TP 07 Spotbeam 4 to EchoStar14 119W TP 04 Spotbeam A2 (A) (H)(San Francisco, CA-ABC)
6439 - KPIX [MPEG4 HD] moved from EchoStar7 119W TP 07 Spotbeam 4 to EchoStar14 119W TP 04 Spotbeam A2 (A) (H)(San Francisco, CA-CBS)
6442 - KRON [MPEG4 HD] moved from EchoStar7 119W TP 07 Spotbeam 4 to EchoStar14 119W TP 04 Spotbeam A2 (A) (H)(San Francisco, CA-MNT)
6440 - KNTV [MPEG4 HD] moved from EchoStar7 119W TP 07 Spotbeam 4 to EchoStar14 119W TP 04 Spotbeam A2 (A) (H)(San Jose, CA-NBC)
7485 - WGSA [MPEG2 SD] moved from EchoStar7 119W TP 07 Spotbeam 14 to EchoStar14 119W TP 04 Spotbeam B18 (A) (H)(Baxley, GA-CW)
7480 - WJCL [MPEG2 SD] moved from EchoStar7 119W TP 07 Spotbeam 14 to EchoStar14 119W TP 04 Spotbeam B18 (A) (H)(Savannah, GA-ABC)
7481 - WTOC [MPEG2 SD] moved from EchoStar7 119W TP 07 Spotbeam 14 to EchoStar14 119W TP 04 Spotbeam B18 (A) (H)(Savannah, GA-CBS)
7482 - WSAV [MPEG2 SD] moved from EchoStar7 119W TP 07 Spotbeam 14 to EchoStar14 119W TP 04 Spotbeam B18 (A) (H)(Savannah, GA-NBC)
7486 - WVAN [MPEG2 SD] moved from EchoStar7 119W TP 07 Spotbeam 14 to EchoStar14 119W TP 04 Spotbeam B18 (A) (H)(Savannah, GA-PBS)
5657 - KITV2 [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 1 to EchoStar14 119W TP 05 Spotbeam A27 (A) (H)(Honolulu, HI-N/A)
5669 - KHON2 [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 1 to EchoStar14 119W TP 05 Spotbeam A27 (A) (H)(Honolulu, HI-N/A)
8900 - KITV [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 1 to EchoStar14 119W TP 05 Spotbeam A27 (A) (H)(Honolulu, HI-ABC)
8901 - KGMB [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 1 to EchoStar14 119W TP 05 Spotbeam A27 (A) (H)(Honolulu, HI-CBS)
8902 - KHNL [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 1 to EchoStar14 119W TP 05 Spotbeam A27 (A) (H)(Honolulu, HI-NBC)
8903 - KHON [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 1 to EchoStar14 119W TP 05 Spotbeam A27 (A) (H)(Honolulu, HI-FOX)
8904 - KFVE [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 1 to EchoStar14 119W TP 05 Spotbeam A27 (A) (H)(Honolulu, HI-MY)
8905 - KHET [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 1 to EchoStar14 119W TP 05 Spotbeam A27 (A) (H)(Honolulu, HI-PBS)
8906 - KBFD [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 1 to EchoStar14 119W TP 05 Spotbeam A27 (A) (H)(Honolulu, HI-NBC)
8907 - KWHE [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 1 to EchoStar14 119W TP 05 Spotbeam A27 (A) (H)(Honolulu, HI-IND)
8908 - KIKU [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 1 to EchoStar14 119W TP 05 Spotbeam A27 (A) (H)(Honolulu, HI-IND)
7487 - WJWJ [MPEG2 SD] moved from EchoStar7 119W TP 05 Spotbeam 14 to EchoStar14 119W TP 04 Spotbeam B18 (A) (H)(Beaufort, SC-PBS)
7250 - WOLO [MPEG2 SD] moved from EchoStar7 119W TP 07 Spotbeam 14 to EchoStar14 119W TP 04 Spotbeam B18 (A) (H)(Columbia, SC-ABC)
7251 - WLTX [MPEG2 SD] moved from EchoStar7 119W TP 07 Spotbeam 14 to EchoStar14 119W TP 04 Spotbeam B18 (A) (H)(Columbia, SC-CBS)
7252 - WIS [MPEG2 SD] moved from EchoStar7 119W TP 07 Spotbeam 14 to EchoStar14 119W TP 04 Spotbeam B18 (A) (H)(Columbia, SC-NBC)
7253 - WACH [MPEG2 SD] moved from EchoStar7 119W TP 07 Spotbeam 14 to EchoStar14 119W TP 04 Spotbeam B18 (A) (H)(Columbia, SC-FOX)
7255 - WZRB [MPEG2 SD] moved from EchoStar7 119W TP 07 Spotbeam 14 to EchoStar14 119W TP 04 Spotbeam B18 (A) (H)(Columbia, SC-CW)
7256 - WRLK [MPEG2 SD] moved from EchoStar7 119W TP 07 Spotbeam 14 to EchoStar14 119W TP 04 Spotbeam B18 (A) (H)(Columbia, SC-PBS)
7483 - WTGS [MPEG2 SD] moved from EchoStar7 119W TP 07 Spotbeam 14 to EchoStar14 119W TP 04 Spotbeam B18 (A) (H)(Hardeeville, SC-FOX)
7254 - WKTC [MPEG2 SD] moved from EchoStar7 119W TP 07 Spotbeam 14 to EchoStar14 119W TP 04 Spotbeam B18 (A) (H)(Sumter, SC-MY)
7080 - WMVT [MPEG2 SD] moved from EchoStar7 119W TP 05 Spotbeam 11 to EchoStar14 119W TP 04 Spotbeam B12 (A) (H)(Milwaukee, WI-PBS)
7081 - WMLW [MPEG2 SD] moved from EchoStar7 119W TP 05 Spotbeam 11 to EchoStar14 119W TP 04 Spotbeam B12 (A) (H)(Milwaukee, WI-IND)
104 - IDEA [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A)
134 - SHNBC [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A)
137 - QVC [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A)
210 - CSPAN [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A)
211 - CSPN2 [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A)
212 - NASA [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A)
222 - HSN [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A)
225 - C&T [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A)
228 - SHNBC [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A)
230 - ICTV [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A)
260 - TBN [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A)
261 - EWTN [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A)
299 - REELZ [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A)
469 - ORDER [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A)
641 - TVJPN [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 1 to EchoStar14 119W TP 05 Spotbeam A27 (A)
5836 - TST [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (NA)
7040 - ALSKA [MPEG2 SD] moved from EchoStar7 119W TP 09 Spotbeam 2 to EchoStar14 119W TP 01 Spotbeam A24 (A) (H)
9404 - CSPAN [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A) (H)
9409 - TBN [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A) (H)
9411 - NAUHS [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A) (H)
9412 - UCTV [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A) (H)
9417 - EWTN [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A) (H)
9602 - BTV [SD TV] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A)
9648 - IDEA [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A)
19073 - HSNAP [DATA] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar14 119 TP 09 ConUS beam (A)
Transponder Changes:
EchoStar14 119 TP 09 ConUS beam 20000 QPSK 7/8 added
EchoStar14 119W TP 05 Spotbeam A27 changed from 20000 QPSK 5/6 to 20000 QPSK 7/8
EchoStar7 119W TP 04 ConUS beam 20000 QPSK 7/8 removed
EchoStar7 119W TP 07 Spotbeam 4 21500 8PSK 5/6 removed
Channels in the system: 7056
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2010 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v10.05.04
© 2010 - All Rights Reserved - SatelliteGuys Incorporated
I think there are other moves.
I assume you are talking about the CONUS moves from E7 to E14. As long as the channel stays on the same transponder and only the satellite is switched there will be no change in the tables to report for these channels. Which is why you don't see any reports saying E14 is carrying 8 CONUS transponders now.
digiblur
I notice that the uplink isn't updated in The List, i thought that it was done automatically , is there a problem?
I just checked and the file was updated around 6am this morning during the daily sports moves. I glanced at 119 and see some channels on the new beams. What do you see that is wrong?
D
5/24/2010 3:07pm - Uplink Activity Report - 4 changes
D
5/24/2010 9:07pm - Uplink Activity Report - 12 changes
