Telemundo on 79 W
The BLSA shows only one signal at 11904 H. AMC 2 should be on station at 79° West by now. I'm not sure if they are planning to switch from AMC 5 to AMC 2. AMC 5 is running out of juice.
That's why I keep losing it... I thought the motor was not going to the right place, but it may be that the signal gets too weak for my CS 8000 to pick up...
The SatHawk won't pick it up on a blind scan. To get it, I had to enter the transponder manually. And I had to enter is as 11903 rather than 11904, which doesn't make a lot of sense in light of the fact that when it was on 11900, I had to enter it as 11901! (i.e., it was off-frequency in the OTHER direction)
It also doesn't scan as KTEL-DT anymore. The SatHawk scans it as Ch-1, and of course they've never fixed the fact that when you do a blind-scan, it nukes all your manually-entered channel names :(
I don't seem to be able to get this channel anymore. I get 125 W with strong signal, all the way to 72 W, also with strong signal. However, 116.8 W and 79 W, I can't get any signal... the same happens to anything East of 63 W (but it MAY be due to the loss of LOS, even though I got a feed on 58 W once...
I am getting it right now at 90% Quality.
But on my box it scans in as TV1-10900H But it used to scan in as K-tel.
10903 H 2170
Is it just me or is Telemundo down? Last week I was able to watch it one night on 11900 H, but now I get no signal.
I have tried both frequencies, but no signal at all: 79W 11903 H 2170 and 11900 H 2170.
Telemundo @79w has been varying a lot lately. I get it on two tps: 11900 and 11904.
Some weeks ago when 11904 appeared it had a stronger signal, at least 10% more than 11900 and seemed more stable, but lately they are both the same, very low and sometimes not even locking at all.
I'm using a 30" and before all this happened I was getting 99%. Wonder if they ever will get it back to those levels? I was thinking of getting a larger dish but from what I´m reading here even some of you with 36" are having trouble, so I don´t know what to do either.
