is a HR20-100s compatible with SWM/Whole Home dvr?
Yes they are but you need to wire them a little different. The HR20-100 can not power the DECA module on the SWiM tuner port. You need to split the cable running to the HR20 and plug the Deca module into tuner 2 and use band stop filter and run a line to tuner 1.
I was lucky and had the setup prior to the techs understanding this and they swapped my HR20 with an HR24 at no costs.
So basically, the way I have my r16 plugged into the swm?
And this will still work for deca?
If only one line is being run in the room, how would I still do this?
Could I use any type of 2 way splitter for that?
Would that lower the quality of the signal received?
... So is the hr20 compatible or not? I already have mrv, I found a good deal on an hr20 and wanted to know if it could work.
Yes it is as you were told more than one time here. I will try to find the diagram that shows you how you have to hookup the HR20-100.
New Technology: DirecTV Ethernet Coaxial Adapter
Satellite finder meter and directions?
