OK guys need some help here. Finally started playing with the 7150 (rebadged DSR-4800) and ran into a couple issues. Hooked up a couple audio cables (with wires stripped) to the terminal strips on it. Unit is slaved to the Geosat which right now was on 87W C-Band.
Tuned in a "feed" that is DCII and the audio came through just fine. Tried Nasa and the audio worked too. The issue I have been running into is some of the feeds the audio works and some dont. Here are the examples I tried tonight
-DCII feed....worked
-NASA....worked
-MeTV....nope
-ThisTV....symbol rate too low (the 7150 only goes down to 3250 s/r)
-The mux with @Sports and the 2 spanish channels..nope
-The audio only mux with "Focus on the Family"...yep. Lots of audio on there
So then I tried 99W
-Nets...worked
-KCWY NBC..worked
-MyTV...nope
-World Harvest..nope
-GDMX feeds...nope <-----these I really want to work
-The Spanish channels (Univision, WAPA)...nope
Then I tried 125W and all the SD feeds on there worked fine (12180, 12162, 12169, 12175)
Most when I hit the audio button show info but a couple its blank. I waited a couple minutes for the channel to finish downloading the VCT to see if that was it and it wasn't
So what am I doing wrong?
Also there are 2 mic cable audio outputs...I have a couple 3 pin mic to RCA cables and those dont work at all....something in the settings?
Also I have to slave mine. If I hook it directly it wont work at all. I assume these cant work with a LNBF and needs the 3 wire polarity changing LNB instead?
Otherwise it seems to be working pretty good.
-NASA....worked
-MeTV....nope
So then I tried 99W
-Nets...worked
-KCWY NBC..worked
-MyTV...nope
