Ok, so first off Im new to this fourm and to the whole sat stuff so bare with me. I had HD Dvr installed and another hd reciver with the home dvr service, I had one line coming from the dish into my house and then a cheap 1-2 spliter, I was using Swm. Now I have moved into a house that already has directtv but they are using b-band, I have the b-bands, and they are setup for hd, so I ran my coax from slimline3 then split it with the same spliter I had at the old place and conected it to my hd dvr, and I got my service working, but I can only record the show im watching, and I cant the signal to my other box. Can someone help!
to Satelliteguys! To use only one cable, you have to have a swm setup, which you don't. You need two cables to each dvr in order to use both tuners. The splitter only works with a swm setup. You do need the bbcs, though. Is there another port on the lnb that you can connect to? If not, you may need to get a multiswitch, or convert the new setup to swm.
