2/4/2011 3:16pm - Uplink Activity Report - 95 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 2/4/2011 3:16pm - 95 changes
Uplink Comparison Range: 02/04/2011 03:00P - 02/04/2011 03:15P
Channel Additions:
916 - ERASP [MPEG AUDIO] added to EchoStar15 61.5W TP 04 ConUS beam (ERA Sport Radio) (A) (H)
6849 - UP9 [MPEG4 HD] added to EchoStar15 61.5W TP 12 ConUS beam (Virtual Channel) (NA)
6850 - UP9 [MPEG4 HD] added to Echostar15 61.5W TP 23 ConUS beam (Virtual Channel) (NA)
6851 - UP9 [MPEG4 HD] added to Nimiq5 72.7W TP 06 ConUS beam (Virtual Channel) (NA)
6852 - UP9 [MPEG4 HD] added to Nimiq5 72.7W TP 17 ConUS beam (Virtual Channel) (NA)
9393 - 3ABN [MPEG2 SD] added to EchoStar15 61.5W TP 04 ConUS beam (3 Angels Broadcasting Network) (A) (FP)
9402 - HHS [MPEG2 SD] added to EchoStar15 61.5W TP 04 ConUS beam (US Dept of Health & Human Services TV) (A) (H)
9405 - PNTGN [MPEG2 SD] added to EchoStar15 61.5W TP 04 ConUS beam (The Pentagon Channel) (A) (H)
9406 - ARTS [MPEG2 SD] added to EchoStar15 61.5W TP 04 ConUS beam (Classic Arts Showcase) (A) (H)
9413 - ALMA [MPEG2 SD] added to EchoStar15 61.5W TP 04 ConUS beam (Almavisión) (A) (H)
9418 - PAEC [MPEG2 SD] added to EchoStar15 61.5W TP 04 ConUS beam (Panhandle Area Ed. Consortium) (A) (H)
9850 - KBS [MPEG2 SD] added to EchoStar15 61.5W TP 04 ConUS beam (Korean Broadcasting Service America) (A) (H)
9902 - D61.5 [FTA] added to EchoStar15 61.5W TP 04 ConUS beam (You have a Dish at 61.5°) (A)
9996 - ECC [MPEG2 SD] added to EchoStar15 61.5W TP 04 ConUS beam (Echostar Communications Corp.) (A) (H)
Channel Removals:
6802 - UP2 (NA) [MPEG2 SD] removed from EchoStar8 77W TP 13 ConUS beam (Virtual Channel)
6805 - UP4 (NA) [MPEG2 SD] removed from EchoStar8 77W TP 02 ConUS beam (Virtual Channel)
6807 - UP10 (NA) [MPEG2 SD] removed from EchoStar8 77W TP 18 ConUS beam (Virtual Channel)
6813 - UP4 (NA) [MPEG2 SD] removed from EchoStar15 61.5W TP 06 ConUS beam (Virtual Channel)
6813 - UP4 (NA) [MPEG2 SD] removed from EchoStar8 77W TP 08 ConUS beam (Virtual Channel)
6842 - UP11 (NA) [MPEG4 HD] removed from EchoStar8 77W TP 04 ConUS beam (Virtual Channel)
6844 - UP11 (NA) [MPEG4 HD] removed from EchoStar8 77W TP 20 ConUS beam (Virtual Channel)
Channel Moves:
6293 - WHTM [MPEG4 HD] moved from EchoStar15 61.5W TP 12 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Washington, DC-Harrisburg, PA-ABC) (A) (H)
6294 - WHP [MPEG4 HD] moved from EchoStar15 61.5W TP 12 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Washington, DC-Harrisburg, PA-CBS) (A) (H)
6295 - WGAL [MPEG4 HD] moved from EchoStar15 61.5W TP 12 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Washington, DC-Lancaster, PA-NBC) (A) (H)
6296 - WPMT [MPEG4 HD] moved from EchoStar15 61.5W TP 12 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Washington, DC-York, PA-FOX) (A) (H)
6297 - WLYH [MPEG4 SD] moved from EchoStar15 61.5W TP 12 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Washington, DC-Lancaster, PA-CW) (A) (H)
6298 - WITF [MPEG4 SD] moved from EchoStar15 61.5W TP 12 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Washington, DC-Harrisburg, PA-PBS) (A) (H)
6299 - WGCB [MPEG4 SD] moved from EchoStar15 61.5W TP 12 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Washington, DC-Red Lion, PA-REL) (A) (H)
8873 - WJAN [MPEG4 SD] moved from Echostar15 61.5W TP 23 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:West Palm Beach, FL-Miami, FL-IND) (A) (H)
5190 - WQAD [MPEG4 HD] moved from Nimiq5 72.7W TP 06 ConUS beam to EchoStar8 77W TP 06 ConUS beam (Mkt:Davenport, IA-Moline, IL-ABC) (A) (H)
5191 - WHBF [MPEG4 HD] moved from Nimiq5 72.7W TP 06 ConUS beam to EchoStar8 77W TP 06 ConUS beam (Mkt:Davenport, IA-Rock Island, IL-CBS) (A) (H)
5192 - KWQC [MPEG4 HD] moved from Nimiq5 72.7W TP 06 ConUS beam to EchoStar8 77W TP 06 ConUS beam (Mkt:Davenport, IA-Davenport, IA-NBC) (A) (H)
5193 - KLJB [MPEG4 HD] moved from Nimiq5 72.7W TP 06 ConUS beam to EchoStar8 77W TP 06 ConUS beam (Mkt:Davenport, IA-Davenport, IA-FOX) (A) (H)
5194 - KQIN [MPEG4 HD] moved from Nimiq5 72.7W TP 06 ConUS beam to EchoStar8 77W TP 06 ConUS beam (Mkt:Davenport, IA-Davenport, IA-PBS) (A) (H)
5195 - WQPT [MPEG4 HD] moved from Nimiq5 72.7W TP 06 ConUS beam to EchoStar8 77W TP 06 ConUS beam (Mkt:Davenport, IA-Moline, IL-PBS) (A) (H)
5196 - KGCW [MPEG4 HD] moved from Nimiq5 72.7W TP 06 ConUS beam to EchoStar8 77W TP 06 ConUS beam (Mkt:Davenport, IA-Burlington, IA-CW) (NA)
7604 - KGCW [MPEG4 SD] moved from Nimiq5 72.7W TP 06 ConUS beam to EchoStar8 77W TP 06 ConUS beam (Mkt:Davenport, IA-Burlington, IA-CW) (A) (H)
5270 - WEHT [MPEG4 HD] moved from EchoStar15 61.5W TP 04 ConUS beam to EchoStar8 77W TP 18 ConUS beam (Mkt:Evansville, IN-Evansville, IN-ABC) (A) (H)
5271 - WEVV [MPEG4 HD] moved from EchoStar15 61.5W TP 04 ConUS beam to EchoStar8 77W TP 18 ConUS beam (Mkt:Evansville, IN-Evansville, IN-CBS) (A) (H)
5272 - WFIE [MPEG4 HD] moved from EchoStar15 61.5W TP 04 ConUS beam to EchoStar8 77W TP 18 ConUS beam (Mkt:Evansville, IN-Evansville, IN-NBC) (A) (H)
5273 - WTVW [MPEG4 HD] moved from EchoStar15 61.5W TP 04 ConUS beam to EchoStar8 77W TP 18 ConUS beam (Mkt:Evansville, IN-Evansville, IN-FOX) (A) (H)
5274 - WNIN [MPEG4 HD] moved from EchoStar15 61.5W TP 04 ConUS beam to EchoStar8 77W TP 18 ConUS beam (Mkt:Evansville, IN-Evansville, IN-PBS) (A) (H)
5275 - WKOH [MPEG4 HD] moved from EchoStar15 61.5W TP 04 ConUS beam to EchoStar8 77W TP 18 ConUS beam (Mkt:Evansville, IN-Owensboro, KY-PBS) (A) (H)
7369 - WAZE [MPEG4 SD] moved from EchoStar15 61.5W TP 04 ConUS beam to EchoStar8 77W TP 18 ConUS beam (Mkt:Evansville, IN-Evansville, IN-CW) (A) (H)
9103 - WBNA [MPEG4 SD] moved from EchoStar15 61.5W TP 12 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Louisville, KY-Louisville, KY-ION) (A) (H)
5270 - WGGB [MPEG4 HD] moved from Nimiq5 72.7W TP 17 ConUS beam to EchoStar8 77W TP 22 ConUS beam (Mkt:Springfield, MA-Springfield, MA-ABC) (NA)
5272 - WWLP [MPEG4 HD] moved from Nimiq5 72.7W TP 17 ConUS beam to EchoStar8 77W TP 22 ConUS beam (Mkt:Springfield, MA-Springfield, MA-NBC) (A) (H)
5273 - WGGBD [MPEG4 HD] moved from Nimiq5 72.7W TP 17 ConUS beam to EchoStar8 77W TP 22 ConUS beam (Mkt:Springfield, MA-Springfield, MA-FOX) (NA)
5274 - WGBY [MPEG4 HD] moved from Nimiq5 72.7W TP 17 ConUS beam to EchoStar8 77W TP 22 ConUS beam (Mkt:Springfield, MA-Springfield, MA-PBS) (A) (H)
6531 - WSHM [MPEG4 SD] moved from Nimiq5 72.7W TP 17 ConUS beam to EchoStar8 77W TP 22 ConUS beam (Mkt:Springfield, MA-Springfield, MA-CBS) (A) (H)
5160 - WCPO [MPEG4 HD] moved from EchoStar15 61.5W TP 18 ConUS beam to EchoStar8 77W TP 04 ConUS beam (Mkt:Cincinnati, OH-Cincinnati, OH-ABC) (A) (H)
5161 - WKRC [MPEG4 HD] moved from EchoStar15 61.5W TP 18 ConUS beam to EchoStar8 77W TP 04 ConUS beam (Mkt:Cincinnati, OH-Cincinnati, OH-CBS) (A) (H)
5162 - WLWT [MPEG4 HD] moved from EchoStar15 61.5W TP 18 ConUS beam to EchoStar8 77W TP 04 ConUS beam (Mkt:Cincinnati, OH-Cincinnati, OH-NBC) (A) (H)
5163 - WXIX [MPEG4 HD] moved from EchoStar15 61.5W TP 18 ConUS beam to EchoStar8 77W TP 04 ConUS beam (Mkt:Cincinnati, OH-Newport, KY-FOX) (A) (H)
5166 - WCET [MPEG4 HD] moved from EchoStar15 61.5W TP 18 ConUS beam to EchoStar8 77W TP 04 ConUS beam (Mkt:Cincinnati, OH-Cincinnati, OH-PBS) (A) (H)
5170 - WCVN [MPEG4 HD] moved from EchoStar15 61.5W TP 18 ConUS beam to EchoStar8 77W TP 04 ConUS beam (Mkt:Cincinnati, OH-Covington, KY-PBS) (A) (H)
5171 - WPTO [MPEG4 HD] moved from EchoStar15 61.5W TP 18 ConUS beam to EchoStar8 77W TP 04 ConUS beam (Mkt:Cincinnati, OH-Oxford, OH-PBS) (A) (H)
8354 - WSTR [MPEG4 SD] moved from EchoStar15 61.5W TP 18 ConUS beam to EchoStar8 77W TP 04 ConUS beam (Mkt:Cincinnati, OH-Cincinnati, OH-MY) (A) (H)
5170 - WHTM [MPEG4 HD] moved from EchoStar15 61.5W TP 12 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Harrisburg, PA-Harrisburg, PA-ABC) (A) (H)
5171 - WHP [MPEG4 HD] moved from EchoStar15 61.5W TP 12 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Harrisburg, PA-Harrisburg, PA-CBS) (A) (H)
5172 - WGAL [MPEG4 HD] moved from EchoStar15 61.5W TP 12 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Harrisburg, PA-Lancaster, PA-NBC) (A) (H)
5173 - WPMT [MPEG4 HD] moved from EchoStar15 61.5W TP 12 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Harrisburg, PA-York, PA-FOX) (A) (H)
9020 - WLYH [MPEG4 SD] moved from EchoStar15 61.5W TP 12 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Harrisburg, PA-Lancaster, PA-CW) (A) (H)
9021 - WITF [MPEG4 SD] moved from EchoStar15 61.5W TP 12 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Harrisburg, PA-Harrisburg, PA-PBS) (A) (H)
9022 - WGCB [MPEG4 SD] moved from EchoStar15 61.5W TP 12 ConUS beam to EchoStar8 77W TP 20 ConUS beam (Mkt:Harrisburg, PA-Red Lion, PA-REL) (A) (H)
6477 - WTAE [MPEG4 HD] moved from EchoStar15 61.5W TP 06 ConUS beam to EchoStar8 77W TP 02 ConUS beam (Mkt:Pittsburgh, PA-Pittsburgh, PA-ABC) (A) (H)
6478 - KDKA [MPEG4 HD] moved from EchoStar15 61.5W TP 06 ConUS beam to EchoStar8 77W TP 02 ConUS beam (Mkt:Pittsburgh, PA-Pittsburgh, PA-CBS) (A) (H)
6479 - WPXI [MPEG4 HD] moved from EchoStar15 61.5W TP 06 ConUS beam to EchoStar8 77W TP 02 ConUS beam (Mkt:Pittsburgh, PA-Pittsburgh, PA-NBC) (A) (H)
6480 - WPGH [MPEG4 HD] moved from EchoStar15 61.5W TP 06 ConUS beam to EchoStar8 77W TP 02 ConUS beam (Mkt:Pittsburgh, PA-Pittsburgh, PA-FOX) (A) (H)
6482 - WPCW [MPEG4 HD] moved from EchoStar15 61.5W TP 06 ConUS beam to EchoStar8 77W TP 02 ConUS beam (Mkt:Pittsburgh, PA-Jeannette, PA-CW) (A) (H)
6483 - WQED [MPEG4 HD] moved from EchoStar15 61.5W TP 06 ConUS beam to EchoStar8 77W TP 02 ConUS beam (Mkt:Pittsburgh, PA-Pittsburgh, PA-PBS) (A) (H)
8134 - WPMY [MPEG4 SD] moved from EchoStar15 61.5W TP 06 ConUS beam to EchoStar8 77W TP 02 ConUS beam (Mkt:Pittsburgh, PA-Pittsburgh, PA-MY) (A) (H)
8137 - WPCB [MPEG4 SD] moved from EchoStar15 61.5W TP 06 ConUS beam to EchoStar8 77W TP 02 ConUS beam (Mkt:Pittsburgh, PA-Greensburg, PA-REL) (A) (H)
8142 - WQEX [MPEG4 SD] moved from EchoStar15 61.5W TP 06 ConUS beam to EchoStar8 77W TP 02 ConUS beam (Mkt:Pittsburgh, PA-Pittsburgh, PA-SHOP) (A) (H)
5200 - WCHS [MPEG4 HD] moved from Echostar15 61.5W TP 23 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Charleston, WV-ABC) (A) (H)
5201 - WOWK [MPEG4 HD] moved from Echostar15 61.5W TP 23 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Huntington, WV-CBS) (A) (H)
5202 - WSAZ [MPEG4 HD] moved from Echostar15 61.5W TP 23 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Huntington, WV-NBC) (A) (H)
5203 - WVAH [MPEG4 HD] moved from Echostar15 61.5W TP 23 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Charleston, WV-FOX) (A) (H)
7319 - WQCW [MPEG4 SD] moved from Echostar15 61.5W TP 23 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Portsmouth, OH-CW) (A) (H)
7321 - WPBY [MPEG4 SD] moved from Echostar15 61.5W TP 23 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Huntington, WV-PBS) (A) (H)
7322 - WOUB [MPEG4 SD] moved from Echostar15 61.5W TP 23 ConUS beam to EchoStar8 77W TP 08 ConUS beam (Mkt:Charleston, WV-Athens, OH-PBS) (A) (H)
6846 - UP11 [MPEG4 HD] moved from EchoStar8 77W TP 06 ConUS beam to EchoStar15 61.5W TP 06 ConUS beam (Virtual Channel) (NA)
6847 - UP11 [MPEG4 HD] moved from EchoStar8 77W TP 22 ConUS beam to EchoStar15 61.5W TP 18 ConUS beam (Virtual Channel) (NA)
14578 - WGBY2 [EPG] moved from Nimiq5 72.7W TP 17 ConUS beam to EchoStar8 77W TP 22 ConUS beam (OTA EPG:Springfield, MA)(NA)
14662 - WGBY3 [EPG] moved from Nimiq5 72.7W TP 17 ConUS beam to EchoStar8 77W TP 22 ConUS beam (OTA EPG:Springfield, MA)(NA)
14831 - WGBY4 [EPG] moved from Nimiq5 72.7W TP 17 ConUS beam to EchoStar8 77W TP 22 ConUS beam (OTA EPG:Springfield, MA)(NA)
Channel Renames:
9790 - TEST - EchoStar14 119W TP 10 ConUS beam renamed to DISH (Dish Network Information Channel) (A) (FP)
9791 - TEST - EchoStar11 110W TP 22 ConUS beam renamed to DISH (Dish Network Information Channel) (A) (FP)
9791 - TEST - Nimiq5 72.7W TP 22 ConUS beam renamed to DISH (Dish Network Information Channel) (A) (FP)
Transponder Changes:
Nimiq5 72.7W TP 06 ConUS beam changed from 22500 QPSK TURBO CODED 5/6 to 21500 8PSK 2/3
Nimiq5 72.7W TP 17 ConUS beam changed from 22500 QPSK TURBO CODED 5/6 to 21500 8PSK 2/3
EchoStar15 61.5W TP 04 ConUS beam changed from 22500 QPSK TURBO CODED 5/6 to 20000 QPSK 7/8
EchoStar15 61.5W TP 06 ConUS beam changed from 22500 QPSK TURBO CODED 5/6 to 20000 QPSK 7/8
EchoStar15 61.5W TP 12 ConUS beam changed from 22500 QPSK TURBO CODED 5/6 to 21500 8PSK 2/3
Echostar15 61.5W TP 23 ConUS beam changed from 22500 QPSK TURBO CODED 5/6 to 20000 QPSK 7/8
Channels in the system: 7463
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2011 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v10.10.28
© 2011 - All Rights Reserved - SatelliteGuys Incorporated
Seriously though I have never seen those channels in the 6293-6299 block. are they supposed to be available to DC market subs? I will asume they are just 'hidden" for now and may someday appear---though I susspect not.
IIRC,
There's a county in PA that's technically in the DC market, but Harrisburg is Significantly Viewed...
J
Right now they are just slates that say Dish Network. 9790 is flagged as an SD channel and 9791 is flagged as an HD channel. I am receiving both on my 722.....
ty but i wonder what those slates are going to be for what channels :)
My guess would be DISCOVERY FIT HEALTH channel and/ or OWN HD.Could do without the OWN HD though.Dont know though just guessing.....
D
2/3/2011 3:01pm - Uplink Activity Report - 4 changes
D
2/7/2011 12:46pm - Uplink Activity Report - 9 changes
