HR20 thru HR24 CE Release 3/4
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,031
436
Central Michigan
Systems in this CE
HR20-100 • HR20-700
HR21-100 • HR21-200 • HR21-700
HR22-100 • R22-100 • R22-200
HR21Pro • HR23-700
HR24-100 • HR24-200 • HR24-500
Window of opportunity to download:
Friday, March 4, 2011 11:00PM - 2:30AM ET
Saturday, March 5, 2011 11:00PM - 2:30AM ET
Risk Level for this Download:
High Risk
New features
None
Improved/Updated
Under the hood
Notes
HR24 series is now merged with the HR2x and R22's.
This CE may remove your guide cache if you did not download a previous CE. Please allow up to 24 hrs to restore your full 14 day guide.
You will lose your guide cache when reverting from CE to national.
Please do not report sluggish issues or missing search results within the first 12 hours after download.
"Under-the-hood" and "stability" improvements are expected with every release and are not noted here.
New features
CE:26:01(0x046B)
Enhanced Channel Banner!
whitewolf8214
40,379
799
Space
Systems in this CE
HR20-100 • HR20-700
HR21Pro • HR23-700
what you mean losing my guide cache when reverting from ce to national and merged?ty for help :)
Jimbo
Cutting Edge
Jul 14, 2005
68,924
7,274
NW Ohio - Buckeye Country
IF you should have to go back to the National Release, the Guide will have to repopulate, the extended guide is generally the only issue as it normally takes about 24 hrs.
The first 3 days is usually populated right away.
sparkyscott
Feb 25, 2011
10
N. Mich
My pause, frame by frame issue has been corrected on my HR21-200.
Also my % of space on the hd is back down 20% where it should be.
My hR24-500, all is well so far, except for the c.c. bar issue I had for a few minutes, ok now..
ChrisK114
1,051
4
Mount Pleasant,SC
Just wanted everyone to know that be wary of going back to NR. I have a HR23-700 and went back to NR due to the sound still coming thru home theater in the middle of the night whenever a recording would start. Well when i did I lost all series links and all recordings made since the CE release.
ke4pym
44
NC
On a HR24/100, when I turn the receiver off the first time, audio output comes back about 30 seconds after the unit turns off. Using the optical output. I've not observed this issue on a HR24/200.
Also, sometimes, it will not turn off on the first or second push of the system off button. Usually by the 3rd push it will turn off.
CE's for the Weekend of 3.18
H21 / H23 / H24 CE Release 3/4
