Can you get low SRs on your Openbox S9?
Jullius
229
La Crosse, WI
I'm having issues scanning in 11900 H 2170 on 79W with my Openbox S9. Is this normal? I can get it on other receivers I have. I think I remember reading the Openbox has issues with low SR, but I thought that was only during blind scanning. Does it just have issues in general tuning low SRs?
If your openbox has the green tint, as mine did, (with that firmware) the blindscan was super fast but missed all the low SR TP's. I would say starting around 3000. I could get these by programming in the freq and SR. I've since loaded HDS2-11-03-21:01A2M and the green tint is fixed, the blind scan is quite a bit slower, but seems to get the Low SR TP's during a blindscan.
I was having trouble getting 11900 H 2170 on 79W even when entering it manually. It worked with my AZbox flawlessly though. I might try changing the firmware and see if works better. Thanks
Will my receivers able work with these motors - SG2100 and HH-90
Did Antenna TV add more affiliates?
