HR20 thru HR24 Special Thursday CE 9/15 Only
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,054
456
Central Michigan
Systems in this CE
HR20-100 • HR20-700
HR21-100 • HR21-200 • HR21-700
HR22-100 • R22-100 • R22-200
HR21Pro • HR23-700
HR24-100 • HR24-200 • HR24-500
Window of opportunity to download:
Thursday, September 15, 2011 11:59PM - 2:30AM ET
Risk Level for this Download:
High Risk
New features
None for this release
Improved/Updated
Fixed red screen issue
Notes
Please send logs along with all reports.
You will need to re-enter IAMANEDGECUTTER to send logs
If you experience video issues, please perform a reboot.
This CE will remove your guide cache. Please allow up to 24 hrs to restore your full 14 day guide.
You will lose your guide cache when reverting from CE to national.
Please do not report sluggish issues or missing search results within the first hours.
"Under-the-hood" and "stability" improvements are expected with every release and are not noted here.
New features
None
Improved/Updated
{CE 28:01} 0x04FD
UMightLike!
{CE 28:03} 0x0552
HDGUI
On my HR24-500 when watching an HD recording and using 30sec skip/FF/Rewind functions, the screen image becomes 4X3 and only goes back to normal when you cycle thru the Format button. This also happens when rewinding back within a live buffer.
On my first attempt to watch an SD recording the connection between the receiver and tv was basically reset w/ my TV left saying Searching for source..
My other receiver, HR24-100 hasn't had any issues other than the Guide scrolling on even with the setting set to Off, which the 24-500 did also.
Update.. On the 24-500, After a popup saying "Updating guide data" appeared, my current recording stopped and had only a black screen on any channel.. did a reset and now when I use a DVR function it makes the image look like what Crop does to an SD show, but on HD content. Again it's fixed by pressing the Format button.
HR24 -500, hit 30 second slip back, changed screen format...
Moved this post here for better visibility ... :)
H21/H23/H24 CE Special Thursday 9/15 Only
CE's for Labor Day Weekend
