722k with Sling Adapter - wanted to add External Hard Disk - how?
jdad11
58
3
US
I got the 722k with Sling Adapter and would like to add external hard drive with USB.
How to do this? Looks like the 722k receive only got one USB port and already used by
the Sling Adapter.
There are 2 USB ports, one port is on the back of the receiver under the ethernet port, the other is on the front, behind the door of the left side, the same door the smartcard slot is in.
Does anyone know if the powered hub can use two external hard drives at the same time? I had read at one time the 922 could do 2 or 3 at a time, and was hoping the 722k could do the same.
The only problem that I found is that if your Slingbox is connected to a powered external USB hub is that it interferes with the Powerline connection (if you are using one). At least that was my experience.
Lowest-Priced Qualifying Package - AT120 or Dish Family?
Dish Network Satellite Confiuration Help, 61.5 migrate to 118.7
