Thanks TH2.
I will check the video when I get home this evening and see if it is something I am comfortable with.
Just curious though, is this something the Dish technician should have done when they installed and set-up the equipment?
Not really ... only if the install had been one fully reliant on Dish .. ie, they were bundling your internet and sat service ... and even then many may not know what to do.
Even with new routers, there have been issues with UPnP ... Universal Plug-n-Play was supposed to fix many of the problems users have with special devices and applications (Xbox, Wii, PS3, SlingBox/SlingAdapter, Torrent servers, etc) that require special ports be setup or dedicated for that device/application's use.
In theory everything is wonderful, but in reality, the smallest of glitches can mean that UPnP doesn't work correctly or appears to open ports, but fails to forward packets (network traffice) correctly from local machines ... etc.
The old "stand by" is to create manual Port Forward Rules. Each router/firewall/modem-combo device is slightly different, but they all should support some form of "forwarding" and most if not all should support Static DHCP assignment although they don't always call it static dhcp, they may call it IP Reservation, or Reserved Server, or some such.
Wish the Dish box provided for assigning a Static IP. My Motorola DSL Router doesn't seem to support assign IP address through the Dynamic IP function. But then, it would also be nice if Dish support the original Stand-Alone Sling software with the means to directly provide the IP address (and bypass thier server).
Agree with you there ... I saw that it didn't allow me to manually set one up and I'm like..
:rant:
and then said..
FINE I'll do it in my router!
I'm one of the folks here using DD-WRT on my wireless routers (gateway and bridge routers) Much easier to setup such things with DD than with the myriad of others out there. Mostly the problem comes from *them* the Linksys's, the Dlink's, the Netgear's of the world.. trying to make nice for the "computer idiot" what they really end up doing is dumbing down the content to the point that when you get with someone that *knows* the correct terminology they can't get people where they need to be because everyone calls it something different rather than what it is..
Anyway.. if you'd ID the model of router I'd look to see if there's anything I might find to help you (and anyone else reading)
