Editting a post
Jimbo
71,087
9,583
NW Ohio - Buckeye Country
For some reason, starting today from what I can tell...
If you go into a thread and edit your post, the time and edit shows IN the Post, instead of saying edit by XXX at 8:00pm down below, it's now in the thread.
edit:
I'll try and see if it will do it here.
edit2:
Apparently not, not sure what caused it or if it was a fluke thing, it happened more than once and to others as well in the D* or Sports threads if that helps any.
IF you edit the post after 5 minutes of posting then yes it will show the "Edited by"
but it use to be real little and after it like this
edited by Iceberg (then the time)
But now its showing right below it like this
Edited by Iceberg (then the time)
So is this staying like this, or can it be minimized like it was before.
Yes. The sponsors ads at the top really need to be a bit bigger, too.
And it would be nice to be able to edittt thread titles in the event of a misspelling. ;)
I am not a great speller, nor does my spell check work well with this site for some unknown reason. When I go back and edit a post , the edit notation has no line space.
I am not the only bad speller around here.:rolleyes::rolleyes:
No, you aren't, our site owner holds the record... :D
I am not a great speller, nor does my spell check work well with this site for some unknown reason. When I go back and edit a post , the edit notation has no line space. (needs one)
Apparently someone corrected the edit notation spacing issue.;) lol
oops, spoke to soon!:eek:
Will this ever be able to be corrected? Or is it just a flaw in the software?
No I'm sure as Scott gets time he will get it figured out and fixed..;)
This is still happening and very annoying because it looks like a part of the post.
Any way to at least change the font back to very small like it was before? Or at least move it down a few lines, so it's not a part of the post?
I'll bet this is related to the randomly changing font size issue...
Edit: Adding this as a test
Now I see small letters. Looks right....
test
how can i figure out my password?
Can't go to DirecTV forum
