Not sure why this is. it seems like i have duplicate channels in the 9000-9999 range . Called Dish support they didnt have any reason?
thanks
thanks
For HD, the higher numbers are the channel numbers, sd is at the lower location. The HD channels are then mapped to the same number as the sd to make them easier to find for longtime subscribers adding HD.
The 9000 range channels are indeed the HD definition channels for our programming packages. DISH doesn't want customers having to search thousands of channels for their favorite channels so we take that HD channle and "map it down" to the standard channel. TNT is channel 138 which is where customer have been use to watching the channel, so we take the channel from 9420 and send to 138 so your channel has the HD feed. This is called mapping down the channels. We do this for locals as well as they can be at the lower channel numbers and easier for our customers to find.Not sure why this is. it seems like i have duplicate channels in the 9000-9999 range . Called Dish support they didnt have any reason?
thanks
maryb@Dish Network said:The 9000 range channels are indeed the HD definition channels for our programming packages. DISH doesn't want customers having to search thousands of channels for their favorite channels so we take that HD channle and "map it down" to the standard channel. TNT is channel 138 which is where customer have been use to watching the channel, so we take the channel from 9420 and send to 138 so your channel has the HD feed. This is called mapping down the channels. We do this for locals as well as they can be at the lower channel numbers and easier for our customers to find.
I guess the real question is why is the necessary to begin with...inquiring minds
For the convenience of humanoids and to keep it simple.
Probably about the only time I see d-tv doing something better then Dish.Why does Dish feel they have to do this but Directv doesn't? There are no higher number repeat channels, SD/HD are the same. TBS is 247, TBS HD is also 247, they're next to each other in the guide (if you don't side SD duplicates, which I don't because I can't stand the stretch-o-vision on the Turner HD channels). Locals only appear once, on the actual number. I used to have Dish and just thought it was the way it was and never thought about it until now that Directv doesn't do this. (OR, does Directv do it in a way that customers don't see it. They must with locals for reasons described earlier.)
Tampa8 said:Think of this way using locals. Think of how many cities/areas have channel 3, or 4 etc... To make it easy Dish wants you do know you can go to channel 3 just like you would with an antenna, or usually from your cable company. They can only have one channel 3 on the satellite if they simply put your channel 3 on their system. But, they can put as many channels 3's as they need at higher numbers, so mine might be 5698, yours might be 6433, etc. But then they "Map Down" or simply replicate that channel for you at what looks like channel 3. You are actually picking the higher number. Sort of like Windows and using a shortcut. You know to go to the desktop to open WORD, but WORD isn't where you are clicking it's taking you to a another usually harder place to find to get to WORD.
Ok makes sense for locals (honestly I was aware of the need to do this for locals) but why is it necessary for everything else...
Ross
Sent from my rooted DROIDX (Liberty Gingerbread) using SatelliteGuys
Dish could "Hide" the extra channels but instead they chose to leave that "option" available to the consumer.. (With the lock and hide feature)
107 4670 | CMDY [107 4670] CMDY [107 4670] | Comedy Central Comedy Central | MPEG4 SD MPEG4 SD | 61.5°W 61.5°W | 18 18 | 8PSK (2/3) 8PSK (2/3) | ConUS beam ConUS beam | AT120 | Available Available |
What I don't understand in all this, is the SD channels are mirrored, but the 4-digit channel number IS hidden. Why don't/can't they do something similar for the HD channels?
