HELP..Need procedure for 2 Hopper/4 Joey Install
eddwall
SatelliteGuys Guru
147
Get 1 Hopper loaded , then Joey 1 loaded, then Joey 2 loaded.... Then disconnect or power down the 1st Hopper & Joey 1 & 2 ..... Then get Hopper 2 loaded ....then Joey 3 loaded , then Joey 4 loaded ... The connect or power up the 1st Hopper and Joey 1 & 2 ...both Hoppers should be up with their 4 Joeys...... Pls verify for me. Installer working on dish/lnb and we are both a little concerned about a 2 Hopper 4 Joey system. Thanks
Come on 3 hrs have passed..... Two Hoppers + 4 Joeys.... What is the power up & load process...I want 2 Joeys to see 1Hopper and the other 2 Joeys to see the other Hopper if possible. Until the software update where everything is tied all together...
Both Hoppers must be hooked up, take their downloads and then activated before any Joeys are even connected. When the Hoppers are ready to activate he needs to call Dish and give them the Hopper receiver numbers and smart card numbers then give the Joey numbers and smart card numbers. Once the Hoppers are activated you can connect the Joeys and they will activate through the Hoppers. The Joeys go pretty quick.
When the Joeys go through the wizard set up it will show what Hoppers it can link to. I was only able to link my 2 Joeys to 1 of my Hoppers instead of 1 Joey to each Hopper. I'm still experimenting.
Thank you very much....will we be able to put two joeys on each Hopper or will it be 3 joeys on 1 Hopper and 1 Joey on the other Hopper.
I just did a 2H 4J install this afternoon. Install both Hoppers and get them up and running first. Once they say they're ready for activation call in and activate all 6 units at the same time. Do not power up any Joeys until the Hoppers are both watching TV. Then power up the Joeys and follow the wizard one by one. You can put 3J on 1H if you want. You can even change which Hopper a Joey is linked to at any time - just go into the Whole Home setting and pick which one you want to link to.
How long did your install take?
About 4 Hours (had to rebuild the install a little bit too). The main thing that set me back a while though was one of the Hoppers would only show a black screen when I picked any channel other than 101. It took me a while to figure out that the smart card wasn't registering (showed all zeros on sys info). Once I removed and reinserted it, had to wait 10 min for the next hit and then it worked.
Dish was never able to see my work order so it took forever. I created 3 work ordered and they still never saw it.
Any Tailgaters Try To Upgrade to H/J?
My ViP to Hopper checklist
