H2x / HR2x CE Release 3/30
jcrandall
Proud Staff Member
Staff member
HERE TO HELP YOU!
Apr 3, 2005
11,055
459
Central Michigan
Systems in this CE
H21 • H23 • H24 • H25
HR20 • HR21 • HR22 • HR23 • HR24
(all manufacturers)
Note that this is now a unified thread for ALL HD receivers and DVRs except H20.
Window of opportunity to download:
Friday, March 30, 2012 11:00PM - 2:30AM ET
Saturday, March 31, 2012 11:00PM - 2:30 AM ET
Risk Level for this Download:
Customer Candidate
New features
None
Improved/Updated
Under the hood
Notes
You may lose your guide cache
Please allow up to 24 hrs to restore your full 14 day guide
Your STB may restart during idle time within the first 24-48 hours of CE download
Please do not report sluggishness or missing search results within the first 12 hours
Please send logs along with all reports, including MRV issues
Previous Release Information:
"Under-the-hood" and "stability" improvements are expected with every release and are not noted here.
New features
None
Improved/Updated
{CE:30:01} 0x5B3/0x45B3
Playlist optimization
Minor UI updates
Game Lounge
Trick Play
Stability fixes
Under the Hood
{CE:30:02} 0x05B6/0x45B6
Under the Hood
PREV key in PIG
Minor YouTube/Pandora updates
Minor Playlist updates
Stability fixes
{CE:30:04} 0x05BA/0x45BA
Channel banner
Closed Captioning
{CE:30:06} 0x05BE/0x45BE
Pandora (HR only)
HR24 up yet????
Sent from my SPH-D710 using Tapatalk
I like UP
Sent from my New IPAD using Tapatalk HD
Pink Screen
Often when changing channels or bringing up guide, menu, etc., I will get a pink overlay to entire screen. Turning DVR off then on will fix it. Tried reset, no change.
HR-21-700
Often when changing channels or bringing up guide, menu, etc., I will get a pink overlay to entire screen. Turning DVR off then on will fix it. Tried reset, no change. HR-21-700
havent seen that. Using HDMI? maybe a handshake issue? try unseating and reseating the cable or a red button reset.
Tried all that. No change. It started doing this immediately after the CE download Friday night. Guess I'll have to go back to NR.
Finally determined it would only give me the "pink screen" image when a channel change also changed the display resolution. Changed native resolution setting to "off" and now no more problems.
The Nightmare Continues
I wasn't showing any MLB Extra Innings channels in my guide so I went to Directv website and reauthorized my receiver. MLB channels still weren't showing so I did a red button reset. MLB channels now in guide. Wonderful!
However, I now have no playlist recordings, no series manager, no history, absolutely nothing. Still showing software version 0x5C5 from Friday night.
Any ideas anyone? If I go back to NR, is there any hope at all for my playlist?
HR21-700 w/ext. hard drive
You lost your Playlist ?
If so, Yes, I would go back to the NR and see if it comes back, then I would try Fridays CE (if there is one) and see what happens then.
Yep. Lost my playlist. Trying to download NR now. It says searching for 059F but not downloading. Very frustrating. I guess NR not available right now. Will try later.
59F IS available now, it's the NR, it HAS to be available.
Try again, make sure your doing the same as you would fora CE release or you'll not get the NR.
4th attempt no good either. Will not download. I'm using the CE method. 02468.
Finally got NR 059F to download. Still no playlist.
CE's for the last Weekend of March
H2x / HR2x CE Release 4/6
