Hi love the hopper and joey, yet when i play the sirius xm channels the music details do not move around. The question is wont this cause burn in? Thanks Harv
DWS44 said:Has there been any indication of how the channels will look with the album art? Is it going to be a static screen similar to the Music Choice on cable, or more like the screensaver approach on the current 622/722 interface with just the art added? I think it would be cool if they could follow the format that the Pandora app uses on the newer Samsung blu-ray players. Basically it is just the album art with song info below it that floats around the screen as a screensaver while the music plays.
For that matter...will the new album show on the older receivers, or just the Hopper/Joey?
You're right. Other than superior image quality, plasma has no advantage over LCD.LCD has improved greatly over the years to where most (if not all) advantages that plasma had are no longer an advantage.
GaryPen said:You're right. Other than superior image quality, plasma has no advantage over LCD.
3HaloODST said:The image quality gap between LCDs and Plasmas has been closed for at least 2 years now. LED backlighting solved the contrast issues.
It has been lessened, not closed. But, if I'm ever in the mood to watch all of the life sucked out of a motion picture so that it looks like a daytime soap opera, I'll be sure to pick up one of the new LCD models.The image quality gap between LCDs and Plasmas has been closed for at least 2 years now. LED backlighting solved the contrast issues.
What you are referring to 120Hz dejudder, and you're right, it sucks, but all you have to do is turn it off. LCD is brighter than Plasma, and LED backlighting has solved the issues with backlight bleeding. Response rate is no longer an issue, so where does that leave Plasma? Only advantage is slightly looking more "film-like." Disadvantages? Burn in, power consumption, weight.
