AV Breakout Extension Cables or Adapters
This is the excitement thread, but since the discussion has gone to specs... will sat AV have the triple composite extension cable for the microHD? If so, what lengths?
I know you have the 3 rca to 3 rca cables but will you have a mini to mini?
We will not be stocking composite AV extensions or mini to mini adapters as there are several tip and ring combinations commonly used. You would probably be best to use the mini to RCA cable that came with your other electronic device along with the microHD AV mini to RCA breakout then use 3 RCA female barrels (F/F) to attach yellow to yellow, white to white and red to red.
microHD Web Sales Counter
DIY Video: GEOSATpro microHD - Firmware Upgrade via USB
