Starting to loose signal strength on transponders with Dishnetwork
babcockcm
2
Alaska
Hello please help
My signal strengths were really good for my transponders on Dishnetwork several month ago. Now they are getting weak. I live in Alaska the satellite that Iam locked onto is 119 I have a 6' dish and use dish DVR 625 here are my there is nothing blocking my dish. I changed the cable ends and it made no difference. Here are my signal strengths.
Transponder:
1=0, 2=0, 3=0, 4=0, 5=0, 6=36, 7=30, 8=0, 9=14, 10=22, 11=37, 12=11, 13=14, 14=23, 15=45, 16=9, 17=13, 18=32, 19=45, 20=12, 21=23
Please help me
Chris
If at all possible run a temp line from dish to receiver (depending on your lnbf if it has additional outputs try a different port) if that's still happening and you're positive the dish has not moved and there is no break in the line such as barrels or a switch chances are your lnbf is on its way out
Hello please help
Transponder:
Please help me
Chris
I wish you had told us you had checked alignment,what else haven't you told us about the system? You are using a 6' prime focus or offset dish solid or mesh? What type of LNB are you using? What type of temperatures are you seeing in Alaska compared to earlier good signal levels? You are using a 625 DVR single or dual cables are both tuners bad?
Issues with my setup. Help?
Wrong locals after service address change
