Upgraded 311 to 512 DVR complete signal loss?
madaradio
Sep 15, 2012
2
Can
Hi guys, first time poster.
I've been running a 311 receiver for the past year year with no issues. I recently purchased a 512 dvr receiver and am having issues getting a signal to both inputs.
The dish hasnt moved or been damaged in any way so I have no idea why I'm not getting a signal. I'm running dual LNB's, into a sw44 switch, into a dp plus separator, then finally into sat 1 and sat 2 inputs. When I run a check with both inputs connected I get signal through to sat input 1 (110 + 119) but nothing to sat input 2 (says not verified), and thus cannot proceed.
When I disconnect sat input 2, and re run a check, I get an ok signal (110 + 119) and am able to watch TV but cannot record and watch at the same time or use PIP since input 2 is disconnected.
It appears that signal to 119 is weak, could the this be why once the signal is split I dont get anything? Maybe readjust the dish?
any help would be much appreciated! thanks!
boba
11,350
1,035
Dorchester, TX.
SW44 says you are using Legacy LNB, DPP separator can only be used with DPP LNB/Switches. Your equipment isn't compatible.
madaradio
Sep 15, 2012
2
Can
thanks for the quick reply. So does that mean I need new LNBs and switch? or just new switch? Would a sw21 switch be compatible?
boba
11,350
1,035
Dorchester, TX.
Any switch that starts with SW is LEGACY and won't work with DP or DPP switches and LNBs. If all you have is a 311 and a 625 on a dish 500 a DPP TWIN is a cheap solution.
129 & 61.5
Loyalty Department
