Echostar 16 Launch - November 20 2012
Waiting patiently for Dish to add CW in HD. Hope this will be the answer to that problem.
If you have a full power HD CW station in your market, you should get CW in HD by the end of next year when Dish has to have all the HD local channels. Note it is stand alone channels, not subchannels.
Does Dish have to have HD in all local markets or just all the HD in the markets in which Dish provides HD?
I believe it's around 3 months of testing before it reaches its final destination but I could be wrong.
It's been one month of testing for past Echostar/Dish sats, but it can be a week or two more or even a week LESS in one instance a few years ago. One must also factor in the time it takes to move the sat from the testing slot to the assigned operations slot. So, about a month or so if tests go well.
Any news? Been almost a week since we heard anything.
Most likely they are in the process testing. Latest TLE has it at 67.05, close to the planned testing location. Dish generally does not talk much about testing.
The only news we might be apt to hear (assuming testing goes well) before they move it to 61.5 is if a SatGuys member happens to point a Dish at the bird with a spectrum analyzer and reports they can see test signals. Other than that, no news is good news until early January (as if there is no movement by then, there might be a problem)
Indeed, there is a Santa (for Dish that is).
The next proton/breeze launch was Dec 8 ( from the same launch pad). It had a 4th stage breeze anomaly which shut down 4 minutes early.
The satellite will be able to reach geo using satellite fuel but life will be shortened from 15 to 11 years.
This is two failures in one year. The last time, several top guys were fired so more heads will likely roll.
Defintely not good news for the International Launch Services sales dept.
EchoStar 16 expected to complete transfer for all 61.5W service sometime in last half of January. -- from EchoStar 15 filing--- "EchoStar currently expects EchoStar 16 to
arrive at the nominal 61.5° W.L. orbital location sometime in late December or early January.
Once there, EchoStar will work to transfer traffic from EchoStar 15 to EchoStar 16 without
interruption to service to DISH network customers. Once all traffic is transferred, which
EchoStar anticipates will be sometime in the latter half of January, EchoStar expects to move
EchoStar 15 to 44.9º W.L."
Will Dish install 2 dishes
bangor locals moved from conus to TID#1132 - no longer appear
