Hopper to Joey over Ethernet
MagnumVP
34
CA
Is it possible once the Joey is setup via Coax, to run the Joey over my Wired Ethernet if both the Hopper and Joey are connected?
Edit: I found in another thread that this is possible. Is there anything that I should be aware of regarding this change?
Only thing I can think of is that it is NOT a Dish supported method, so if you have any trouble with it, they will not help you unless you connect it via coax.
Also, you'll want to make sure you have enough bandwidth available on your home network to stream HD video.
DIRT
hopper issues
