No signal download on replacement VIP 722DVR
Pk2rmex
3
Mexico
Got 2 722's as a replacement from Dish.....and since the first time I connected them there is always a msg Warning 061 and Im unable to download signal to the receivers.
Checked switch and signal strenght is OK for 110 and 129.....no signal at all for 119 so Im installing another antenna just for 119.
Any comments on whether this is gonna solve the problem?
Check LOS for 119 and check for water damage on connectors that will make signals go out,if you had a meter to test DB's and they were high like 55+ then that is also a good indicator of corroded connectors.
Sorry I got a Dish 1000....can anyone tell me if I need to get signal from 119W in order to download firmware and get the receivers up and running?
If you're not getting 119 on either receiver, could it be the LNBF that's bad?
I would doubt both receivers are bad. or maybe a bad cable for 119?
Rentals on Hopper
MOVING QUESTION
