Cat 5 and wifi might actually work, but it isn't an approved connection. The thing about using coax is it creates a separate network for the video to use that will not disrupt any other traffic on your Ethernet/wireless network. I used a Joey on wireless for a bit and it really bogged down my wireless network.
As an internal tech we've been told (in my area) we would be fired if we set up joey's wirelessly and were found out.
How about the OP's cat5?
The vast majority of the install would still be coax. Installing completely different cabling for only a small portion of the install for Joeys would cost them substantially more money.If Joeys can connect to the Hopper via Coax or Cat 5, why do installers run Coax instead of Cat 5. Wouldn't Cat 5 be easier and cheaper?
Another thought, In many states installers need a special license for running Cat 5 cable.
Cat5 has 4 pair. Two pair could be used for home network and the other two pair could be used for Dish - network.
1. Congratulations, you just broke any ability to run Gigabit Ethernet.
2. Heaven help whoever has to follow behind you since you've completely ignored the wiring standard.
Bad idea, but there's nothing stopping v you from doing this.
Sent from my Samsung Galaxy Note 2 using Tapatalk 2.x
But it works. This whole conversation is outside of standards. In the end, it is up to the user to see what works for them.
cditty:
Very few consumers have the wherewithal to DYI their cabling plants. You're free to go your own way in what I call "unsupported land", but don't expect their support if something goes wrong.
I spend enough time at work with this kind of stuff, so I pick and choose what I'm going out on a limb for at home.
In some states you have to have a license to run coax as well.
What do you do if Dish decides to shut off IP streaming over cat 5? Doesn't take much code to do this... But $20 says there will be complaints should Dish turn off the unsupported functionality.
