I have two Hoppers that have lower signal strength for one of the satellite's transponder than my other two Hoppers. In the Network Setup Tests menu (Yellow - Blue - 3) select Send Status and then select Connection. After the connection test is complete select Check Signal. For satellite 118, tuner #3, transponder #1 the signal strength is 37 to 38 in two of my Hoppers. In my other two Hoppers the strength is 57 to 58 for the same satellite 118, tuner #3, transponder #1. Does anyone know what could be causing the different readings between the four Hoppers? I don't know much how the LNBs and switches/nodes work, but attached is my wiring diagram if someone wants me to swap around the coax to see if it could be an LNB, switch, node, or something else. There must be something causing two Hoppers to have a big difference in readings than the other two. All other satellite signal readings appear normal and everything is working ok. Just thought maybe someone would like a challenge to figure it out. Thanks for any help.
