D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 6/26/2013 3:47pm - 72 changes
Uplink Comparison Range: 06/26/2013 03:31P - 06/26/2013 03:46P
Channel Additions:
6374(18) - WKTB [MPEG4 HD] added to Ciel-2 129W TP 06 Spotbeam 43 (Mkt:Atlanta, GA) (NA)
8910(15) - KUPU [MPEG2 SD] added to EchoStar14 119W TP 05 Spotbeam A27 (Mkt:Honolulu, HI-Waimanalo, HI-IND) (NA)
6690(6) - WRTV [MPEG2 SD] added to EchoStar10 110W TP 18 Spotbeam 13 (Mkt:Lafayette, IN-Indianapolis, IN-ABC) (A) (H)
6692(13) - WTHR [MPEG2 SD] added to EchoStar10 110W TP 18 Spotbeam 13 (Mkt:Lafayette, IN-Indianapolis, IN-NBC) (A) (H)
6693(59) - WXIN [MPEG2 SD] added to EchoStar10 110W TP 18 Spotbeam 13 (Mkt:Lafayette, IN-Indianapolis, IN-FOX) (A) (H)
5190(13) - WLOX [MPEG4 HD] added to Unknown TID#1320 (Mkt:Biloxi, MS-Biloxi, MS-ABC) (NA)
5192(6) - WXXV2 [MPEG4 HD] added to Unknown TID#1320 (Mkt:Biloxi, MS-Gulfport, MS-FOX) (NA)
5193(25) - WXXV [MPEG4 HD] added to Unknown TID#1320 (Mkt:Biloxi, MS-Gulfport, MS-FOX) (NA)
5194(16) - WMAH [MPEG4 HD] added to Unknown TID#1320 (Mkt:Biloxi, MS-Biloxi, MS-PBS) (NA)
6591(14) - WLOX2 [MPEG4 SD] added to Unknown TID#1320 (Mkt:Biloxi, MS-Biloxi, MS-ABC) (NA)
6401(61) - KZJL [MPEG4 HD] added to Ciel-2 129W TP 06 Spotbeam 49 (Mkt:Houston, TX-Houston, TX-N/A) (NA)
6401(61) - KZJL [MPEG4 HD] added to Echostar16 61.5W TP 25 Spotbeam 16 (Mkt:Houston, TX-Houston, TX-N/A) (NA)
6382(24) - KPNZ [MPEG4 HD] added to Ciel-2 129W TP 03 Spotbeam 18 (Mkt:Salt Lake City, UT-Ogden, UT-N/A) (NA)
5150(3) - WHSV [MPEG4 HD] added to Echostar16 61.5W TP 18 Spotbeam 52 (Mkt:Harrisonburg, VA-Harrisonburg, VA-ABC) (NA)
5151(9) - WSVF2 [MPEG4 HD] added to Echostar16 61.5W TP 18 Spotbeam 52 (Mkt:Harrisonburg, VA) (NA)
5152(4) - WRC [MPEG4 HD] added to Echostar16 61.5W TP 18 Spotbeam 52 (Mkt:Harrisonburg, VA-Washington, DC-NBC) (NA)
5153(42) - WSVF [MPEG4 HD] added to Echostar16 61.5W TP 18 Spotbeam 52 (Mkt:Harrisonburg, VA) (NA)
5154(51) - WVPT [MPEG4 HD] added to Echostar16 61.5W TP 18 Spotbeam 52 (Mkt:Harrisonburg, VA-Staunton, VA-PBS) (NA)
248 - MAVTV [MPEG4 HD] added to Ciel-2 129W TP 19 ConUS beam (MavTV HD) (A)
248 - MAVTV [MPEG4 HD] added to Nimiq5 72.7W TP 26 ConUS beam (MavTV HD) (A)
249 - CI [MPEG4 HD] added to EchoStar11 110W TP 19 ConUS beam (Crime & Investigation Network) (A)
249 - CI [MPEG4 HD] added to Nimiq5 72.7W TP 24 ConUS beam (Crime & Investigation Network) (A)
279 - CCNEW [MPEG2 SD] added to EchoStar11 110W TP 08 ConUS beam (A)
279 - CCNEW [MPEG4 SD] added to Nimiq5 72.7W TP 22 ConUS beam (A)
393 - PRST [MPEG2 SD] added to EchoStar14 119W TP 15 ConUS beam (A) (FP)
393 - PRST [MPEG4 SD] added to Nimiq5 72.7W TP 22 ConUS beam (A) (FP)
9817 - TVINT [MPEG2 SD] added to Anik F3 118.7W TP 15 ConUS beam (NA)
Channel Removals:
6690 - WBND (A) (H) [MPEG2 SD] removed from EchoStar14 119W TP 01 Spotbeam A11 (Mkt:Lafayette, IN-South Bend, IN-ABC)
6692 - WNDU (A) (H) [MPEG2 SD] removed from EchoStar14 119W TP 01 Spotbeam A11 (Mkt:Lafayette, IN-South Bend, IN-NBC)
6693 - WSJV (A) (H) [MPEG2 SD] removed from EchoStar14 119W TP 01 Spotbeam A11 (Mkt:Lafayette, IN-Elkhart, IN-FOX)
713 - WLLOW (A) (H) [MPEG2 SD] removed from Anik F3 118.7W TP 03 ConUS beam
14188 - KLRT2 (NA) [EPG] removed from EchoStar10 110W TP 18 Spotbeam 15 (OTA EPG:Little Rock, AR)
14976 - WBBJ3 (NA) [EPG] removed from EchoStar10 110W TP 20 Spotbeam 14 (OTA EPG:Jackson, TN)
19007 - VODAP (A) [DATA] removed from EchoStar11 110W TP 16 ConUS beam
19007 - VODAP (A) [DATA] removed from Nimiq5 72.7W TP 21 ConUS beam
Channel Package Flag Changes:
5255(21) - KHBSD [MPEG4 HD] - Ciel-2 129W TP 03 Spotbeam 37 changed to Available (H) (Mkt:Ft. Smith, AR-Fort Smith, AR-CW)
5260(13) - WBKO [MPEG4 HD] - Echostar16 61.5W TP 32 Spotbeam 09 changed to Available (H) (Mkt:Bowling Green, KY-Bowling Green, KY-ABC)
5261(4) - WNKYD [MPEG4 HD] - Echostar16 61.5W TP 32 Spotbeam 09 changed to Available (H) (Mkt:Bowling Green, KY-Bowling Green, KY-N/A)
5262(40) - WNKY [MPEG4 HD] - Echostar16 61.5W TP 32 Spotbeam 09 changed to Available (H) (Mkt:Bowling Green, KY-Bowling Green, KY-NBC)
5263(33) - WBKOD [MPEG4 HD] - Echostar16 61.5W TP 32 Spotbeam 09 changed to Available (H) (Mkt:Bowling Green, KY-Bowling Green, KY-N/A)
5264(48) - WKGB [MPEG4 HD] - Quetzsat1 77W TP 20 ConUS beam changed to Available (H) (Mkt:Bowling Green, KY-Bowling Green, KY-PBS)
5265(24) - WKYU [MPEG4 HD] - Echostar16 61.5W TP 32 Spotbeam 09 changed to Available (H) (Mkt:Bowling Green, KY-Bowling Green, KY-PBS)
6427(16) - KUNP [MPEG4 HD] - EchoStar10 110W TP 29 Spotbeam 44 changed to Available (H) (Mkt:Portland, OR-La Grande, OR-UNI)
5190(7) - KVII [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 17 changed to Available (H) (Mkt:Amarillo, TX-Amarillo, TX-CBS)
5191(10) - KFDA [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 17 changed to Available (H) (Mkt:Amarillo, TX-Amarillo, TX-CBS)
5192(4) - KAMR [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 17 changed to Available (H) (Mkt:Amarillo, TX-Amarillo, TX-NBC)
5193(14) - KCIT [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 17 changed to Available (H) (Mkt:Amarillo, TX-Amarillo, TX-FOX)
5194(2) - KACV [MPEG4 HD] - Echostar16 61.5W TP 25 Spotbeam 17 changed to Available (H) (Mkt:Amarillo, TX-Amarillo, TX-N/A)
7684(33) - KCPN [MPEG4 SD] - Echostar16 61.5W TP 25 Spotbeam 17 changed to Available (H) (Mkt:Amarillo, TX)
7685(18) - KPTF [MPEG4 SD] - Echostar16 61.5W TP 25 Spotbeam 17 changed to Available (H) (Mkt:Amarillo, TX-Farwell, TX-N/A)
7686(36) - KTMO [MPEG4 SD] - Echostar16 61.5W TP 25 Spotbeam 17 changed to Available (H) (Mkt:Amarillo, TX)
240 - PRST [MPEG2 SD] - EchoStar14 119W TP 15 ConUS beam removed from free preview (A)
240 - PRST [MPEG4 SD] - Nimiq5 72.7W TP 22 ConUS beam removed from free preview (A)
361 - MAVTV [MPEG4 HD] - Ciel-2 129W TP 19 ConUS beam changed to shown in non-sub's guides (MavTV HD) (A) (H)
361 - MAVTV [MPEG4 HD] - Nimiq5 72.7W TP 26 ConUS beam changed to shown in non-sub's guides (MavTV HD) (A) (H)
368 - CI [MPEG4 HD] - EchoStar11 110W TP 19 ConUS beam changed to shown in non-sub's guides (Crime & Investigation Network) (A) (H)
368 - CI [MPEG4 HD] - Nimiq5 72.7W TP 24 ConUS beam changed to shown in non-sub's guides (Crime & Investigation Network) (A) (H)
677 - ARYDI [MPEG2 SD] - Anik F3 118.7W TP 27 ConUS beam changed to free preview (A) (Ary Digital USA (Urdu))
689 - QTV [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed to free preview (A) (ARY Qu'ran TV Urdu (Sunni-Pakistani))
738 - GETPJ [MPEG2 SD] - Anik F3 118.7W TP 26 ConUS beam removed from free preview (A)
789 - MNRMA [MPEG2 SD] - Anik F3 118.7W TP 08 ConUS beam changed to Available (H)
9590(103) - HOPR [MPEG4 HD] - EchoStar11 110W TP 19 ConUS beam changed to Available (FP)
9590(103) - HOPR [MPEG4 HD] - Nimiq5 72.7W TP 13 ConUS beam changed to Available (FP)
9914 - NOWTV [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam removed from free preview (A)
9915 - NOWTV [MPEG4 HD] - Anik F3 118.7W TP 23 ConUS beam removed from free preview (A)
9942 - NOWHR [MPEG2 SD] - Anik F3 118.7W TP 02 ConUS beam removed from free preview (A)
9943 - NOWBN [MPEG2 SD] - Anik F3 118.7W TP 03 ConUS beam removed from free preview (A)
Channel Mapdown Changes:
4272 - MAVTV Ciel-2 129W TP 19 ConUS beam mapdown changed from 361 to 248 (MavTV HD) (A) (H)
4272 - MAVTV Nimiq5 72.7W TP 26 ConUS beam mapdown changed from 361 to 248 (MavTV HD) (A) (H)
4287 - CI EchoStar11 110W TP 19 ConUS beam mapdown changed from 368 to 249 (Crime & Investigation Network) (A) (H)
4287 - CI Nimiq5 72.7W TP 24 ConUS beam mapdown changed from 368 to 249 (Crime & Investigation Network) (A) (H)
Transponder Changes:
Unknown TID#1320 21500 8PSK 3/4 added
Channels in the system: 8861
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2013 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v12.09.27
© 2013 - All Rights Reserved - SatelliteGuys Incorporated.
Channel Additions:
Channel Removals:
(FP) = Free Preview
