Why it's so fun?Ok. Now let's let this pointless argument die.
Sent from my iPhone 4S using Forum Runner
Followup: my 722 in solo mode definitely will put out anamorphic widescreen on the TV2 outputs. This is called "normal" according to repeated pressing of the format button. So all I do is select "wide" on my brand new HDTV and voila; picture is pretty darn good for an HD channel over an SD output (composite) on a 32" TV.
The only trouble is that I didn't really want to be in solo mode. Why oh why won't Dish do the right thing and allow anamorphic on TV2 when a duodvr receiver is in dual mode?
99.9999% of Dish subs have never even heard of anamorphic, much less use it.
Dish receivers are designed for mass market use and that excludes anamorphic displays.
So for the 2 or 3 Dish subs that want it -- nope.
Good point, Krell. I dunno. Sounds like it could be feasible. But with ViPs being the previous model line, unlikely to change at this point, unless it's a simple software update and enough people make noise about it???
People have been making noise about this for years. It's not going to change. I sympathize with The Krell because I use TV2 output for a second hdtv myself. But I realize that asking Dish to "fix" this is a waste of time. Dish wants people to move on to the H/J system, and isn't going to spend a dime paying an engineer to change the software of the dual tv dvrs if that what was needed. And if it is built into the hardware then they won't release an updated version of the unit.Good point, Krell. I dunno. Sounds like it could be feasible. But with ViPs being the previous model line, unlikely to change at this point, unless it's a simple software update and enough people make noise about it???
It would then be a 16 X 9 displayed on a 4 X 3 field. What that would yield would most likely be a postage stamp display. AKA black bars all the way around. Not what you are asking for. It would take more s/w adjustments than they want to spend the time on. It is probably not considered worth the time or effort for the few that have asked for it.You lost me. There's an HD downconverter turning HD channels into SD channels on TV2, simultaneously with full HD operation on a different channel for TV1. So why can't this hardware simply present an anamorphic SD signal on TV2? This consumes the exact same bandwidth as any other SD signal. It will do fullscreen SD signals on TV2 no problem. But it insists on letterboxing (or zooming) the HD channel. One might even argue that zooming is more complicated to the hardware than anamorphic output.
The 622/722/722K units were made when most households with hdtv's only had one. When multiple hdtv's became more common the 922 was released and now there's the H/J. That's why it works the way it does. It's difficult to change because Dish doesn't want to spend the money to fix it. It is what it is. The only way to "fix" it, is to connect TV2 out to a sdtv and then get another hd receiver/dvr for your other hdtv. Which is probably what Dish wants us to do.Why is this so difficult? Every DVD player in existence can put out an anamorphic SD signal. Why can't my 722? (Well, it can in solo mode.)
Yes, the modulated TV1 output in dual mode acts just as if you were watching it on TV1, with all the format options available. It's a shame they couldn't have been available for the TV2 output.I forget, are the format options on the modulated TV1 output available in dual mode? At least that way you'd have the option when there are no viewing conflicts.
I think we all agree on the ease and desirability. And, sadly, on the likelihood of ever seeing it.
