D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 8/14/2013 3:47pm - 74 changes
Uplink Comparison Range: 08/14/2013 03:31P - 08/14/2013 03:46P
Channel Additions:
6682(5) - WMC [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 14 (Mkt:Jonesboro, AR-Memphis, TN-NBC,) (A) (H)
6383(31) - KLAX [MPEG4 HD] added to Echostar16 61.5W TP 22 Spotbeam 15 (Mkt:Alexandria, LA-Alexandria, LA-ABC,) (NA)
6384(35) - KALBD [MPEG4 HD] added to Echostar16 61.5W TP 22 Spotbeam 15 (Mkt:Alexandria, LA-Alexandria, LA-CBS,) (NA)
6385(5) - KALB [MPEG4 HD] added to Echostar16 61.5W TP 22 Spotbeam 15 (Mkt:Alexandria, LA-Alexandria, LA-NBC,) (NA)
6386(48) - WNTZ [MPEG4 HD] added to Echostar16 61.5W TP 22 Spotbeam 15 (Mkt:Alexandria, LA-Natchez, LA-FOX,) (NA)
6387(41) - KBCA [MPEG4 HD] added to Echostar16 61.5W TP 32 Spotbeam 15 (Mkt:Alexandria, LA-Alexandria, LA-CW,) (NA)
6388(26) - KLPA [MPEG4 HD] added to Echostar16 61.5W TP 32 Spotbeam 15 (Mkt:Alexandria, LA-Alexandria, LA-PBS,) (NA)
6530(12) - WBKB2 [MPEG2 SD] added to Ciel-2 129W TP 11 Spotbeam 22 (Mkt:Alpena, MI-Alpena, MI-CBS,) (A) (H)
6367(39) - WLVT [MPEG4 HD] added to Echostar16 61.5W TP 23 Spotbeam 03 (Mkt:Philadelphia, PA-Allentown, PA-PBS,) (NA)
817 - ORDER [MPEG2 SD] added to EchoStar14 119W TP 09 ConUS beam (PPV Event Pre-Order) (A)
817 - ORDER [MPEG4 SD] added to Nimiq5 72.7W TP 29 ConUS beam (PPV Event Pre-Order) (A)
818 - ORDER [MPEG4 HD] added to EchoStar11 110W TP 10 ConUS beam (PPV Event Pre-Order) (A)
818 - ORDER [MPEG4 HD] added to Nimiq5 72.7W TP 29 ConUS beam (PPV Event Pre-Order) (A)
876 - ORDER [MPEG2 SD] added to EchoStar14 119W TP 09 ConUS beam (PPV Event Pre-Order) (A)
876 - ORDER [MPEG4 SD] added to Nimiq5 72.7W TP 29 ConUS beam (PPV Event Pre-Order) (A)
877 - ORDER [MPEG4 HD] added to EchoStar11 110W TP 10 ConUS beam (PPV Event Pre-Order) (A)
877 - ORDER [MPEG4 HD] added to Nimiq5 72.7W TP 29 ConUS beam (PPV Event Pre-Order) (A)
5741 - DPU [134] added to Anik F3 118.7W TP 13 ConUS beam (A) (H)
9591(125) - HOPR [189] added to EchoStar11 110W TP 19 ConUS beam (NA)
9591(125) - HOPR [189] added to Nimiq5 72.7W TP 13 ConUS beam (NA)
9944 - NOWBK [MPEG2 SD] added to Anik F3 118.7W TP 26 ConUS beam (NA)
Channel Removals:
6174 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Birmingham, AL)
6174 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Birmingham, AL)
6184 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Huntsville, AL)
6184 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Huntsville, AL)
6223 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Montgomery, AL)
6224 - WGN (NA) [MPEG4 HD] removed from EchoStar14 119W TP 07 ConUS beam (Mkt:Montgomery, AL)
6682 - WPSD (A) (H) [MPEG2 SD] removed from EchoStar10 110W TP 25 Spotbeam 14 (Mkt:Jonesboro, AR-Paducah, KY-NBC,)
6189 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Tucson, AZ)
6175 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Albany, GA)
6183 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Albany, GA)
6190 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Savannah, GA)
6190 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Savannah, GA)
6187 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Evansville, IN)
6187 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Evansville, IN)
6177 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Louisville, KY)
6177 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Louisville, KY)
6176 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Paducah, KY)
6176 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Paducah, KY)
6181 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Shreveport, LA)
6530 - WJRT (A) (H) [MPEG2 SD] removed from EchoStar10 110W TP 20 Spotbeam 13 (Mkt:Alpena, MI-Flint, MI-ABC,)
6185 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Jackson, MS)
6185 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Jackson, MS)
6186 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Jackson, MS)
6186 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Jackson, MS)
6171 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Charlotte, NC)
6171 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Charlotte, NC)
6178 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Cincinnati, OH)
6178 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Cincinnati, OH)
6172 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Cleveland, OH)
6172 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Cleveland, OH)
6173 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Columbia, SC)
6180 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Knoxville, TN)
6180 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Knoxville, TN)
6179 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Memphis, TN)
6179 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Memphis, TN)
6182 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Tyler, TX)
6182 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Tyler, TX)
6188 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Richmond, VA)
6188 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Richmond, VA)
6535 - WBKB2 (NA) [MPEG2 SD] removed from Ciel-2 129W TP 11 Spotbeam 22 (Alpena, MI)
Channel Package Flag Changes:
5291(7) - WTRF [MPEG4 HD] - Echostar16 61.5W TP 27 Spotbeam 30 changed to Available (H) (Mkt:Wheeling, WV-Wheeling, WV-CBS,)
5292(9) - WTOV [MPEG4 HD] - Echostar16 61.5W TP 27 Spotbeam 30 changed to Available (H) (Mkt:Wheeling, WV-Steubenville, OH-NBC,)
5294(44) - WOUC [MPEG4 HD] - Echostar16 61.5W TP 27 Spotbeam 30 changed to Available (H) (Mkt:Wheeling, WV-Cambridge, WV-PBS,)
6790(10) - WTRF3 [MPEG4 SD] - Echostar16 61.5W TP 27 Spotbeam 30 changed to Available (H) (Mkt:Wheeling, WV-Wheeling, WV-CBS,)
6793(32) - WTRF2 [MPEG4 SD] - Echostar16 61.5W TP 27 Spotbeam 30 changed to Available (H) (Mkt:Wheeling, WV-Wheeling, WV-CBS,)
705 - B4U [MPEG2 SD] - Anik F3 118.7W TP 22 ConUS beam changed to free preview (A) (Bollywood 4 U Movies)
716 - B4UMU [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed to free preview (A) (B4U Music)
9428(115) - STYLE [MPEG4 HD] - EchoStar11 110W TP 22 ConUS beam changed to free preview (A) (Style)
9428(115) - STYLE [MPEG4 HD] - Nimiq5 72.7W TP 26 ConUS beam changed to free preview (A) (Style)
9527(111) - DIY [MPEG4 HD] - EchoStar11 110W TP 22 ConUS beam changed to free preview (A) (Do It Yourself Network)
9527(111) - DIY [MPEG4 HD] - Nimiq5 72.7W TP 20 ConUS beam changed to free preview (A) (Do It Yourself Network)
Channel Type Changes:
5314(19) - WZMQ Echostar16 61.5W TP 28 Spotbeam 48 changed from MPEG4 HD to MPEG4 SD (Mkt:Marquette, MI-Marquette, MI-MN,) (NA)
5315(13) - WNMU Echostar16 61.5W TP 28 Spotbeam 48 changed from MPEG4 HD to MPEG4 SD (Mkt:Marquette, MI-Marquette, MI-PBS,) (NA)
Channels in the system: 8896
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2013 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v12.09.27
© 2013 - All Rights Reserved - SatelliteGuys Incorporated.
Channel Additions:
Channel Removals:
(FP) = Free Preview
