8/14/2013 3:47pm - Uplink Activity Report - 74 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 8/14/2013 3:47pm - 74 changes
Uplink Comparison Range: 08/14/2013 03:31P - 08/14/2013 03:46P
Channel Additions:
6682(5) - WMC [MPEG2 SD] added to EchoStar10 110W TP 20 Spotbeam 14 (Mkt:Jonesboro, AR-Memphis, TN-NBC,) (A) (H)
6383(31) - KLAX [MPEG4 HD] added to Echostar16 61.5W TP 22 Spotbeam 15 (Mkt:Alexandria, LA-Alexandria, LA-ABC,) (NA)
6384(35) - KALBD [MPEG4 HD] added to Echostar16 61.5W TP 22 Spotbeam 15 (Mkt:Alexandria, LA-Alexandria, LA-CBS,) (NA)
6385(5) - KALB [MPEG4 HD] added to Echostar16 61.5W TP 22 Spotbeam 15 (Mkt:Alexandria, LA-Alexandria, LA-NBC,) (NA)
6386(48) - WNTZ [MPEG4 HD] added to Echostar16 61.5W TP 22 Spotbeam 15 (Mkt:Alexandria, LA-Natchez, LA-FOX,) (NA)
6387(41) - KBCA [MPEG4 HD] added to Echostar16 61.5W TP 32 Spotbeam 15 (Mkt:Alexandria, LA-Alexandria, LA-CW,) (NA)
6388(26) - KLPA [MPEG4 HD] added to Echostar16 61.5W TP 32 Spotbeam 15 (Mkt:Alexandria, LA-Alexandria, LA-PBS,) (NA)
6530(12) - WBKB2 [MPEG2 SD] added to Ciel-2 129W TP 11 Spotbeam 22 (Mkt:Alpena, MI-Alpena, MI-CBS,) (A) (H)
6367(39) - WLVT [MPEG4 HD] added to Echostar16 61.5W TP 23 Spotbeam 03 (Mkt:Philadelphia, PA-Allentown, PA-PBS,) (NA)
817 - ORDER [MPEG2 SD] added to EchoStar14 119W TP 09 ConUS beam (PPV Event Pre-Order) (A)
817 - ORDER [MPEG4 SD] added to Nimiq5 72.7W TP 29 ConUS beam (PPV Event Pre-Order) (A)
818 - ORDER [MPEG4 HD] added to EchoStar11 110W TP 10 ConUS beam (PPV Event Pre-Order) (A)
818 - ORDER [MPEG4 HD] added to Nimiq5 72.7W TP 29 ConUS beam (PPV Event Pre-Order) (A)
876 - ORDER [MPEG2 SD] added to EchoStar14 119W TP 09 ConUS beam (PPV Event Pre-Order) (A)
876 - ORDER [MPEG4 SD] added to Nimiq5 72.7W TP 29 ConUS beam (PPV Event Pre-Order) (A)
877 - ORDER [MPEG4 HD] added to EchoStar11 110W TP 10 ConUS beam (PPV Event Pre-Order) (A)
877 - ORDER [MPEG4 HD] added to Nimiq5 72.7W TP 29 ConUS beam (PPV Event Pre-Order) (A)
5741 - DPU [134] added to Anik F3 118.7W TP 13 ConUS beam (A) (H)
9591(125) - HOPR [189] added to EchoStar11 110W TP 19 ConUS beam (NA)
9591(125) - HOPR [189] added to Nimiq5 72.7W TP 13 ConUS beam (NA)
9944 - NOWBK [MPEG2 SD] added to Anik F3 118.7W TP 26 ConUS beam (NA)
Channel Removals:
6174 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Birmingham, AL)
6174 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Birmingham, AL)
6184 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Huntsville, AL)
6184 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Huntsville, AL)
6223 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Montgomery, AL)
6224 - WGN (NA) [MPEG4 HD] removed from EchoStar14 119W TP 07 ConUS beam (Mkt:Montgomery, AL)
6682 - WPSD (A) (H) [MPEG2 SD] removed from EchoStar10 110W TP 25 Spotbeam 14 (Mkt:Jonesboro, AR-Paducah, KY-NBC,)
6189 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Tucson, AZ)
6175 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Albany, GA)
6183 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Albany, GA)
6190 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Savannah, GA)
6190 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Savannah, GA)
6187 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Evansville, IN)
6187 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Evansville, IN)
6177 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Louisville, KY)
6177 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Louisville, KY)
6176 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Paducah, KY)
6176 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Paducah, KY)
6181 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Shreveport, LA)
6530 - WJRT (A) (H) [MPEG2 SD] removed from EchoStar10 110W TP 20 Spotbeam 13 (Mkt:Alpena, MI-Flint, MI-ABC,)
6185 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Jackson, MS)
6185 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Jackson, MS)
6186 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Jackson, MS)
6186 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Jackson, MS)
6171 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Charlotte, NC)
6171 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Charlotte, NC)
6178 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Cincinnati, OH)
6178 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Cincinnati, OH)
6172 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Cleveland, OH)
6172 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Cleveland, OH)
6173 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Columbia, SC)
6180 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Knoxville, TN)
6180 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Knoxville, TN)
6179 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Memphis, TN)
6179 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Memphis, TN)
6182 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Tyler, TX)
6182 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Tyler, TX)
6188 - WGN (NA) [MPEG2 SD] removed from EchoStar14 119W TP 18 ConUS beam (Mkt:Richmond, VA)
6188 - WGN (NA) [MPEG4 SD] removed from Nimiq5 72.7W TP 25 ConUS beam (Mkt:Richmond, VA)
6535 - WBKB2 (NA) [MPEG2 SD] removed from Ciel-2 129W TP 11 Spotbeam 22 (Alpena, MI)
Channel Package Flag Changes:
5291(7) - WTRF [MPEG4 HD] - Echostar16 61.5W TP 27 Spotbeam 30 changed to Available (H) (Mkt:Wheeling, WV-Wheeling, WV-CBS,)
5292(9) - WTOV [MPEG4 HD] - Echostar16 61.5W TP 27 Spotbeam 30 changed to Available (H) (Mkt:Wheeling, WV-Steubenville, OH-NBC,)
5294(44) - WOUC [MPEG4 HD] - Echostar16 61.5W TP 27 Spotbeam 30 changed to Available (H) (Mkt:Wheeling, WV-Cambridge, WV-PBS,)
6790(10) - WTRF3 [MPEG4 SD] - Echostar16 61.5W TP 27 Spotbeam 30 changed to Available (H) (Mkt:Wheeling, WV-Wheeling, WV-CBS,)
6793(32) - WTRF2 [MPEG4 SD] - Echostar16 61.5W TP 27 Spotbeam 30 changed to Available (H) (Mkt:Wheeling, WV-Wheeling, WV-CBS,)
705 - B4U [MPEG2 SD] - Anik F3 118.7W TP 22 ConUS beam changed to free preview (A) (Bollywood 4 U Movies)
716 - B4UMU [MPEG2 SD] - Anik F3 118.7W TP 28 ConUS beam changed to free preview (A) (B4U Music)
9428(115) - STYLE [MPEG4 HD] - EchoStar11 110W TP 22 ConUS beam changed to free preview (A) (Style)
9428(115) - STYLE [MPEG4 HD] - Nimiq5 72.7W TP 26 ConUS beam changed to free preview (A) (Style)
9527(111) - DIY [MPEG4 HD] - EchoStar11 110W TP 22 ConUS beam changed to free preview (A) (Do It Yourself Network)
9527(111) - DIY [MPEG4 HD] - Nimiq5 72.7W TP 20 ConUS beam changed to free preview (A) (Do It Yourself Network)
Channel Type Changes:
5314(19) - WZMQ Echostar16 61.5W TP 28 Spotbeam 48 changed from MPEG4 HD to MPEG4 SD (Mkt:Marquette, MI-Marquette, MI-MN,) (NA)
5315(13) - WNMU Echostar16 61.5W TP 28 Spotbeam 48 changed from MPEG4 HD to MPEG4 SD (Mkt:Marquette, MI-Marquette, MI-PBS,) (NA)
Channels in the system: 8896
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2013 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
The SatelliteGuys Uplink Report is powered by Digiblur Technologies! - DigiDish v12.09.27
© 2013 - All Rights Reserved - SatelliteGuys Incorporated
4 new SD/HD PPV channels added. (Egad, my bad, two new SD and HD channels added).
4 Extra Time matches:
Norwich vs Everton
Sunderland vs Fulham
West Ham vs Cardiff
West Brom vs Southampton
I do remember seeing somewhere something about the possibility of Extra Time being "On Demand". But it mentioned and then the thought drifted away in the article, never to be touched again.
What an exciting uplink...and I thought we'd see DISNEY HD, DISNEY JR. HD, ESPNUHD, ESPN NEWS HD...guess we'll have to wait for the next exciting uplink.
I noticed Dtv added QVCHD! Not that I give a rats ass about shopping channels in HD, but if the HD is at or near capacity for the western US what is in the works to remedy that situation? I know switching everyone to mpeg4 receivers would gain some space, but how many slots would it create. Any new hd sats in the works? Seems the E-W arc was a bad idea. Wouldn't it have been better to have a couple of sats feeding both E & W with channels common to all (CNN, SPIKE, etc.) with the fringe sats (61.5 - 129) for localized spotbeams. And what will the 4-K do to the current sat-transponder load?
Interesting that Dish didnt uplink them as HD as WTRF is running THREE HD channels OTA
-1 CBS
-2 FOX
-3 ABC
That is what I want to see... waiting till October is not something that should happen either. CFB season starts in 2 weeks - we need ESPNU in HD now, not half way thru the season!
D
8/18/2013 7:02pm - Uplink Activity Report - 26 changes
D
8/19/2013 12:47pm - Uplink Activity Report - 2 changes
