Wow...three houses away, someone has some big ones! Think I would have kept the cable, if it was anything good! Who in their right mind would do that and think that it wouldn't be noticed?
Yes, I did keep all of the cable up to where it was coupled. I threw their end back onto their property.
A Dish sub contractor. We've seen it happen before.
I'll be honest, I'm starting to suspect that, but not sure. The part of the cable on their property looks like it was fastened against the walls of their roof as if it was done professionally and to top it off, the cabling and connector appears to be the exact same type and connector that was used in my own install. But I guess that's not conclusive since those may be a dime a dozen, but the professionalism ended right when the cable left their property and it was just left to hang all the way across to my house.
I take it your in NY NY?
Did you unbolt the dish so you could move side to side and fix it yourself? The dish should not move when you take the lnbf off. Does your dish move?
But it's pretty darn easy to move left to right to see if signal comes back in.![]()
Yep, how did you guess where I was. Hah! I have not done that for fear of making things worse but I guess when I get nothing, I already am at "worst". I thought he same as well - which was puzzling - that removing the LNBF and connecting another receiver shouldn't have messed anything up. The dish itself seems fairly secure. I was trying to see if the arm holding the LNBF was bent and it did not seem so. I assume that the LNBF is not broken since I am picking up 118 from the other dish that is connected to the 4th port LNBF IN on the main reflector, but you know what happens when you assume. The other thing is - if it wasn't working for me before I discovered the unauthorized port - surely it wasn't working for that person as well - and if not, why did they just leave it connected... Anyway, I really do stink at aligning but in this case perhaps it's worth a try before calling. I just need a helping hand to do so to watch the meters... which prob won't happen until the weekend at earliest. Ugh.
Maybe the neighbor re-peaked your dish so they could get the sat signals there were looking for....how they thought this would go unnoticed is amazing. Must be how they did it in the "old country".
Which would explain why it wouldn't work for me and maybe it worked for them and therefore they left the cable connected. I still can't get over how they thought it would go unnoticed unless they thought I wasn't using it or that this was okay.... That part of me wants to confront them.
I am sure they would of came right out and arrested everyone at the property in question.....yea, right.
LMAO that's what I was thinking too... But I am torn between confronting them or just letting it be unless it occurs again. I think the latter for now. I obviously have their address. I wonder if there is a legit Dish sub registered to that address.
