? can i use switch shaw 2 dishes
bjkrieg
3
mexico
i do see shaw direct uses 22khs switch, but i don't know if i can use a DISH sw21 ? or a dish dp34 ? well be using on 2-7ft dishes. one at each sat. Do i need just to try or does any one know for sure.
thanks for all the info.
Dish switches like the sw21 and dp34 won´t work with Shaw, as you mention you´ll need a 22khz,
I have a shaw setup using 2 dishes and I use a 22khz Ecoda switch, like the one below:
http://www.satelliteav.com/p/shop/?ws_pid=1371&ws_cat=429
A Directv wb68 will work, or 2 22Khz tone switches, the Ecoda or there are many more manufacturers.
Shaw PVR630 Static IP?
Possible to cancel Shaw Direct Installation?
