Switch Question
prt328
43
4
Nomad
I have 3 separate dishes each with a DishPro LNB. I want to connect a VIP 612 DVR and use both inputs but only have 1 wire run from the swaitch. Can anyone confirm I need a DishPro Plus DP33 and one DISH Pro Plus Separator to make this work? Or does it need something else?
You must already have a switch if this is a working system. What switch connects the three dishes? If you want to use both inputs on a 612 you could use a DP34 and run 2 cables from the DP34 to the 612.
You would actually need a DPP33, which are NO longer made but can be found sometimes...or a DPP44 switch. This is presuming you ONLY want to have to use 1 coax to the 612; otherwise, boba's way would work, but w/2 cables to the switch...
The Blaze
protection plan
