Unless it is being compressed for bandwidth concerns. If it is passing it on uncompressed, then yes it would be the same quality.
For instance with Sling from my Hopper to Laptop. The HD feed on my laptop is not as good as the HD feed coming directly from the Hopper. I assume there is some compression or downscaling slightly to ensure stability even on a >6mbps connection.
The one stream limitation is likely to put a stop to account sharing.The had been saying only ONE stream, but this is marketed to the young who do NOT need more than ONE stream.
It already is called that.HEVC is what it will be.
I was giving the others info on the standards.
Sorry, I just find the encoding method intriguing. That it can go frame by frame, and figure out what portions need a higher density of data. And it does this via merely the data. A VBR for video. I just find it fascinating.Exactly what I was thinking.![]()
