4K Joey
toricred
SatelliteGuys Guru
128
30
New Mexico
I am moving into a new house and I need to add a Joey, but it needs to be wireless. I was hoping to hold off until the 4K Joey comes out, but will it be wireless? Also any news on how much longer until it comes out?
There's really no way of telling at this point. Given the much higher bandwidth requirement (at least double), I'd guess that it wouldn't be optimal.
I was afraid of that. The way Dish installed the Duo Node at the new place makes getting coax to the room I want it in very difficult. Part of the problem is a totally unreasonable HOA with regards to running a cable up the side of a house to the attic.
Can I do a tap by the Hopper input to pull the cable from there? Would hardwired Cat 5e or Cat 6 ethernet work instead?
I'm betting your answers will come when the product becomes available. Until then, plan for something hardwired.
Hoping that anything wireless is the answer to any time-dependent data transmission is likely to lead to disappointment.
OK, but putting in a tap right before my Hopper and running the Client line to the other location should work correct? Would it be possible to just run it over ethernet?
No one really knows until it comes out and more info is released for it. All we know now is there is going to be a 4K Joey.
For a current Joey the Tap would be the only supported method, but via the LAN over Cat5 or Wireless USB adapter both work just fine.
A Tap will almost certainly work for a 4K Joey as that would still be Moca and supported infrastructure.
I'd expect Cat5 will still work on an unsupported basis, but wouldn't bet on it. Wireless USB is questionable. But again, until it ships no one will likely know for sure.
Thank you. I just wanted to understand the options. I can do a tap, but it's not completely optimal. I may try the ethernet first, but I wanted to know if it was a completely a waste of time. I didn't think the question was that complex, but maybe people just got focused on the 4K Joey bit because of the thread title I used.
Well, yeah! ;)
I think the 4K joey only indicates that 4K content will be able to be played. Meaning 4K on demands... For the select few that will LIKELY be available.
ESPN2 in game audio.
DVR Interfering with my DISH signal?
