SatelliteGuys.US DishNetwork Uplink Report - 4/20/2015 09:55 - 34 Changes
Uplink Comparison Range: 4/20/2015 09:48 - 4/20/2015 09:55 (PST)
Channel Removals:
4212(215) - WNE [MPEG4 HD] (NA)(H) removed from Echostar16 61.5W TP 10 Conus (WNE)
4212(215) - WNE [MPEG4 HD] (NA)(H) removed from EchoStar11 110W TP 22 ConUS (WNE)
4353(215) - WNE [MPEG4 HD] (NA)(H) removed from Echostar16 61.5W TP 10 Conus (WNE)
4353(215) - WNE [MPEG4 HD] (NA)(H) removed from EchoStar11 110W TP 22 ConUS (WNE)
4477(215) - WNE [MPEG4 HD] (NA)(H) removed from EchoStar11 110W TP 22 ConUS (WNE)
4751 - WNE [MPEG4 SD] (NA)(H) removed from Echostar16 61.5W TP 03 Conus (WNE)
4751 - WNE [MPEG2 SD] (NA)(H) removed from EchoStar14 119W TP 15 ConUS (WNE)
4752 - WNE [MPEG4 HD] (NA)(H) removed from Echostar16 61.5W TP 10 Conus (WNE)
4752 - WNE [MPEG4 HD] (NA)(H) removed from EchoStar11 110W TP 22 ConUS (WNE)
4947(215) - WNE [MPEG4 HD] (NA)(H) removed from EchoStar11 110W TP 22 ConUS (WNE)
5052(215) - WNE [MPEG4 HD] (NA)(H) removed from EchoStar11 110W TP 22 ConUS (WNE)
5370(215) - WNE [MPEG4 HD] (NA)(H) removed from Echostar16 61.5W TP 10 Conus (WNE)
5370(215) - WNE [MPEG4 HD] (NA)(H) removed from EchoStar11 110W TP 22 ConUS (WNE)
5550(215) - WNE [MPEG4 HD] (NA)(H) removed from Echostar16 61.5W TP 10 Conus (WNE)
5550(215) - WNE [MPEG4 HD] (NA)(H) removed from EchoStar11 110W TP 22 ConUS (WNE)
9602(215) - WNE [MPEG4 HD] (NA)(H) removed from Echostar16 61.5W TP 10 Conus (WNE)
9602(215) - WNE [MPEG4 HD] (NA)(H) removed from EchoStar11 110W TP 22 ConUS (WNE)
9652 - WN [MPEG4 SD] (NA)(H) removed from Echostar16 61.5W TP 03 Conus (WN)
9652 - WN [MPEG2 SD] (NA)(H) removed from EchoStar14 119W TP 15 ConUS (WN)
MAP Changed:
4213 - WN [MPEG4 HD] Nimiq5 72.7W TP 23 ConUS map (215) added (WN)(NA)(H)
4213 - WN [MPEG4 HD] EchoStar11 110W TP 19 ConUS map (215) added (WN)(NA)(H)
4352 - WN [MPEG4 HD] Nimiq5 72.7W TP 23 ConUS map (215) added (WN)(NA)(H)
4352 - WN [MPEG4 HD] EchoStar11 110W TP 19 ConUS map (215) added (WN)(NA)(H)
4476 - WN [MPEG4 HD] EchoStar11 110W TP 19 ConUS map (215) added (WN)(NA)(H)
4946 - WN [MPEG4 HD] EchoStar11 110W TP 19 ConUS map (215) added (WN)(NA)(H)
5051 - WN [MPEG4 HD] EchoStar11 110W TP 19 ConUS map (215) added (WN)(NA)(H)
5369 - WN [MPEG4 HD] Nimiq5 72.7W TP 23 ConUS map (215) added (WN)(NA)(H)
5369 - WN [MPEG4 HD] EchoStar11 110W TP 19 ConUS map (215) added (WN)(NA)(H)
5542 - WN [MPEG4 HD] Nimiq5 72.7W TP 23 ConUS map (215) added (WN)(NA)(H)
5542 - WN [MPEG4 HD] EchoStar11 110W TP 19 ConUS map (215) added (WN)(NA)(H)
9653 - WN [MPEG4 HD] Nimiq5 72.7W TP 23 ConUS map (215) added (WN)(NA)(H)
9653 - WN [MPEG4 HD] EchoStar11 110W TP 19 ConUS map (215) added (WN)(NA)(H)
Name Changed:
215 - WNE [MPEG4 SD] Echostar16 61.5W TP 03 Conus renamed to WN (WN)(NA)(H)
215 - WNE [MPEG2 SD] EchoStar14 119W TP 15 ConUS renamed to WN (WN)(NA)(H)
Transponder Changes:
Echostar16 61.5W TP 10 Conus (21.500 8PSK 2/3) removed.
EchoStar11 110W TP 22 ConUS (21.500 8PSK 2/3) removed.
Channels in the system: 9693
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.0
© 2014 - All Rights Reserved - SatelliteGuys Incorporated.
Channel Removals:
MAP Changed:
Name Changed:
(FP) = Free Preview
