AS WITH ALL FILES, USE AT YOUR OWN RISK.
This patch is at the specific request of Michael Electronics. This will resolve AC-3 "no audio" issues on the very latest Mini HD SE hardware. It is available exclusively at SatelliteGuys and FridgeFTA Forums, or through your Amiko Americas Authorized Retailer. It will be released in the near future at the official support site, www.namini.tk and for online upgrade through your Mini HD SE.
- Fix for latest Mini HD SE units with missing AC-3 audio
- Expands PVR timers from 8 to 20.
- General improvements.
To upgrade:
Follow this procedure EXACTLY or you will end up with no satellites at all or Europe birds and you'll wipe all of your channels and settings.
MAKE A BACKUP. This contains the satellites and your current channels, settings and other data. It is needed if you mess up the upgrade. Plug in a USB flash drive. Go to MENU > SYSTEM > SOFTWARE UPGRADE > BACKUP TO USB, arrow down to "Backup to USB" and press OK. You'll end up with an .abs file starting with "bak-"
USB UPDATE
1. Unzip the update package and put the .abs file in the root of a USB flash drive.
2. MENU > SYSTEM > SOFTWARE UPGRADE > UPGRADE BY USB
3. Select the .abs file on the Upgrade File line.
4. BE SURE UPGRADE MODE IS SOFTWARE(NO CHANNEL LIST)
5. Arrow to start and press OK on remote. Your STB will install the new firmware and reboot when done.
(C) 2015 Amiko Americas, Edictum Kft. All rights reserved.
www.amikoalienusa.com
www.namini.tk
To upgrade:
USB UPDATE
www.namini.tk
