Bases Loaded volume lower than ESPNU's Bases Loaded feed
There is always as difference in perceived loudness with Standard Def and High Def on Dish. Is one of the channels a Standard Def and the other a High Def? Otherwise, I would also investigate surround sound issue such as if your AVR is set to "Straight" or something like that. Best to have the AVR set to surround sound when it encounters stereo DD 2.0.
You might want to enable your volume leveling on your Dish receiver if not already...would help out some.
Some AVRs have a setting that needs to be changed to get volume working properly on all channels. Not sure what this is called, but the 2 Hoppers here and a 722k had no issue when connected directly to the TV
