You'll have to get a 'handle' on the dishes geometry. First determine what's not kosher and fix it. Can't tell you how to fix your but the basics are/seem to follow the measure and compare method.
Many times it's one panel that's warped or squished. Measure each . lip corner to lip corner. If only one panel is 'off' remove and 'form' into shape and reinstall. (usually using the second way below)
if it's just a droop - many time it can be 'pulled' into shape
Couple of way to go about this. The first is : Measure the diameter top to bottom lip. and again left to right. Rut a cable and a turnbuckle across the largest measurement. Tighten the turnbuckle to equalize 1) the diameter measurements 2) check the crossed strings for 'touching'. When 'OK" loosening some of the fasteners holding the dish panels together, and retightening, can relieve tension and may hold the dish in shape and allow removal of the cable and turnbuckle.
The second way is to remove the dish from the mount, place face down on a flat surface and loosen and re
tighten the panel fasteners when the panels touch the surface.
( I believe the second method the best, seems like more work but believe it's the quickest and better method)
