I am a 20 year Dish customer who just moved to a condo from a house, and now have to deal with association rules. I had an installer come out to give recommendations, and I submitted a request to have a dish mounted on the INSIDE of my balcony railing (with an RV-ladder pressure mount). That request was denied because the railing is considered a common element.
I see two possible permanent solutions: a tripod mount on the floor of the balcony, or an upside-down pole mount from the header beam of the balcony above. The installer indicated that mounting on a pole from above wasn't an option, but it seems it should work; I would rather not take up any balcony floor space, and there is plenty of headroom. Has anyone tried to mount a dish hanging from above? Would it require some hardware that the installers don't typically carry, since most pole mounts are in the ground, not attached to a beam?
Also, in case figuring this out takes a while, I have considered using a bucket of cement and a pole as a temporary solution. What diameter of pole would I need to put in the cement to mount the dish on? I assume that I would have to prepare the bucket, cement, and pole in advance, but that the installer would have the hardware to mount the dish to the pole. Right?
But, even on this balcony is some place left (from where picture was taken). Clamps, I added just in case, but, in reality, nothing is moving there and tornadoes do not come inside the balcony.
