By this "hub" do you mean just a standard solo node?2 coax to hub, one cable from hub to Hopper3. Scott has mentioned this a few times.
Sent from my SGH-M819N using Tapatalk
The Hopper3 works with the hybrid LnB, per Vivek. That means that nodes no longer work, and with what Scott said earlier, the hub will disable the xip for zip once the H3 is connected. So no node, only a solo hub.By this "hub" do you mean just a standard solo node?
I wonder what a qualifying account is. LOLLikely free since they said "free upgrade with qualifying accounts".
My guess is the same qualifying accounts that could upgrade to a HWS and Super Joey for free today.I wonder what a qualifying account is. LOL
After they retire.You would be surprised.
I know people who have over 30 FULL external hard drives... when the hell will they ever have time to watch everything they recorded?![]()
That is the million $ question, I can't find that info anywhere yet.Is that 16 physical tuners, or rather a new/improved version of Dish PTAT using 4 physical tuners?
The new Hybrid LnBs don't use nodes anymore, there are threads talking about them around.By this "hub" do you mean just a standard solo node?
Yes I found that out laat night in a main thread on it in the "Hopper Zone" forum.The new Hybrid LnBs don't use nodes anymore, there are threads talking about them around.
I think the "Hub" is basically just a Moca connection point. They could have built it into the LNB, but they obviously have a reason why they didn't.Yes I found that out laat night in a main thread on it in the "Hopper Zone" forum.
Wasn't aware of these new "Dish Pro Hybrid" LNBFs.
(Exclusively been a DIRECTV sub. for the past 20 years so haven't kept abreast on the latest on the other side of the fence).
That being said, while I pride myself in being able to grasp how these satellite xpndr selection and signal distribution technologies work, this one has got me pretty much stumped so far. At first glance I thought Dish is using a type of Channel Stacking Switch (CSS) scheme similar the DIRECTV SWiM system for this DPH LNBF.
But with the need for a second coax run from the LNBF for a two Hopper or Hopper + SJ install, that confuses things again and is like a shift back toward their standard DPP frequency block stacking method.
Not even then -- the 9 tuners on my 3 Hoppers are uber plenty.After they retire.
The secret is the new DPH (hybrid) LNBF. It can output DP or DPP or DPX (1 or 2 Hoppers/SuperJoeys) or DPZ for the H3. DPZ is totally different, sort of like DirecTV's SWiM. Instead of stacking bands of transponders like DP/DPP/DPX, it stacks up to 16 individual transponders to feed 16 different tuners. The LNBF selects at power-up DP/DPP/DPX mode or DPZ mode if it detects an H3 or Wally on port 1.That being said, while I pride myself in being able to grasp how these satellite xpndr selection and signal distribution technologies work, this one has got me pretty much stumped so far. At first glance I thought Dish is using a type of Channel Stacking Switch (CSS) scheme similar the DIRECTV SWiM system for this DPH LNBF.
That is interesting info, where did you learn that?The secret is the new DPH (hybrid) LNBF. It can output DP or DPP or DPX (1 or 2 Hoppers/SuperJoeys) or DPZ for the H3. DPZ is totally different, sort of like DirecTV's SWiM. Instead of stacking bands of transponders like DP/DPP/DPX, it stacks up to 16 individual transponders to feed 16 different tuners. The LNBF selects at power-up DP/DPP/DPX mode or DPZ mode if it detects an H3 or Wally on port 1.
Where you going with them, Dish dish even say they were available?Hopper 3 already loaded on our vans...
Does this mean the "all 4 networks on one transponder" trick is not necessary on the H3? (except to make a virtual 19 tuners when PTAT is activated?)The secret is the new DPH (hybrid) LNBF. It can output DP or DPP or DPX (1 or 2 Hoppers/SuperJoeys) or DPZ for the H3. DPZ is totally different, sort of like DirecTV's SWiM. Instead of stacking bands of transponders like DP/DPP/DPX, it stacks up to 16 individual transponders to feed 16 different tuners. The LNBF selects at power-up DP/DPP/DPX mode or DPZ mode if it detects an H3 or Wally on port 1.
For PTAT is still just uses one tuner for all 4 networks.
